Question about Kenmore 75922 Gas Dryer
Dryer Making a Grinding Noise
My dryer is making a grinding noise the whole time it is on. It is heating properly. How can I fix the grinding noise?
Thank you Kenmore Elite gas dryer (75922) vibrating like crazy and now the timer is not working properly
    Novelist:
  • 108 Answers
My guess is either roller wheel(/s) have become FUBAR, or the idler pulley is worn. Either way you aregoing to have to open it up to find out what is going on...
Unplug the dryer.
If the filter is on the top of the dryer, remove it and remove the screws that are located underneath it. If it is on the inside of the door, remove the filter.
On the left and right sides of the washer, where the top panel meets the front panel, there are spring clips that hold the top to the front panel. You can slide a butter knife or spackling knife in the crevice and push them back so that the top can be lifted up (like a car hood).
The front is held on with 5/16" hex sheet metal screws, most likely. Remove it.
Now you can see what is the problem. You might be able to put some oil on the wheels to get rid of the sound, but this will most likely only be a temporary solution.
Posted on Jul 27, 2009
Tip
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Your dryer has started making noises. The common noises that can happen are squeaks, grinding, bumping, clicking, or knocking. I will give some of the common reasons why your clothes dryer could be making these noises.
Loud noise from your dryer often is the result of excessive wear of the parts inside of the clothing dryer.
Many dryers use a type of glides or slide for the drum of the dryer to ride on. As the dryer heats then up they wear away. The heat from the inside of the dryer and the friction heat will eventually wear them down. When the glide material is worn away the metal of the drum will start to rub against the metal support behind the glide. Metal on metal will make a very irritating squeaking noise, or grinding noise. If this happens, replace the glides.
Other dryers use a type of wheel or roller to support the rotating drum. These rollers turn on a sort of bearing that in often no more then a pin through a bushing. After a period of time the lubrication will dry up or otherwise go away and the assembly will quickly wear out and start to make a clicking noise, or a knocking noise, or even a grinding noise. In any case these often make a loud noise that can be very annoying. If you have a wheel or roller that is making noises then replace all of them, because the others are soon going to go bad also.
On some dryers there is a rear drum bearing. This center spindle supports the drum instead of rollers, wheels, or glides. This spindle will have a bearing assembly of some type that it spins on. This bearing also may start to squeak, grind, or make a loud noise.
If you have this type of dryer then you can replace this when it goes bad.
Another source of dryer noise is the belt. The belt often will make a different noise that will be more of a knocking or thumping noise. Pieces of the belt may come out of the belt and it still is not broken. As the gaps in the belt run over the idler pulley or the drive pulley the belt will make a thumping or knocking noise.
The idler pulley can also be a source of noise. This also has a bearing in it that will wear out. The noises made from this are similar to the rollers or wheels. If you have these kinds of noises coming from your dryer, you need to figure out what the exact cause of the problem is so that you know you are changing the right parts. Or you can just change all of the rotating parts to make sure that you get the problem fixed. The parts involved are not that expensive to replace.
Finally the blower wheel that moves air through your dryer can become clogged with dirt and lint or just plain wear out. If it is loose or out of balance it will make all kinds of funny noises. Cleaning it may help but replacement is probably the best fix. If it is still noisy after cleaning, then replace it.
This should give you a good overview of the possible causes for noise from your clothes dryer. As you can see there are numerous possibilities or causes for noise. Take your time and eliminate them one by one till the cause is found. Repairing them is not that hard and the parts are not that costly.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Mar 26, 2010 | Dryers
My dryer is making a horrible noise when turned on and then when the cycle is stopping. the noise continued to happen then began going through the whole time cycle. The dryer is getting hot but it is not...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 17, 2011 | Crosley CDE6000 Electric Dryer
The barrel on my hotpoint dryer is making a grinding noise-
heatman101
May 01, 2011 | Hotpoint NBXR333GGWW Gas Dryer
Dryer is making a very loud grinding, scratching, irritating squeal noise while operating. When it is turned off and manually turn drum grinding noise still there. Any suggestions? I have an extended...
heatman101
Nov 22, 2010 | LG DLE8377 Dryer
Drying is making grinding noise when clothes are in dryer if no clothes no noise
heatman101
Nov 07, 2010 | Maytag Dryers
Admiral electric dryer started making a little rattling noise about a week ago. Now it is so loud it sounds like I'm trying to dry a whole bunch of metal balls. But I'm not, of course. It heats up just...
heatman101
Sep 20, 2010 | Dryers
Noise
heatman101
dhjh
Nov 23, 2008 | Estate TEDS840JQ Electric Dryer
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Kenmore 75922 Gas Dryer Logo
276 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
