700T Cybex treadmill It keeps blowing the 20amp slo blow fuses on the circuit board. The brushes are fine. I did a current draw and get 3.7 amp at 3 mph without walking. When start walking (200lb) It draws about 12.4 amps. Within a couple minutes it blows the fuse. The deck and belt appears to be in good condition. Any suggestions would be greatly appreciated. Thanks... Troy
fridgetech
  • 473 Answers
SOURCE: Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Posted on Nov 19, 2007
MicrowaveSvc
  • 9098 Answers
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
tech48
  • 624 Answers
SOURCE: I have a Marshall G100RCD
You have a shorted output channel. You probably see burnt resistors and very heat stressed areas of the board. That is a sign of the outputs being shorted. Unless you have experience in repaired amplifiers you will not be able to repair this yourself. If you change the burnt resistors, they will most likely burn up again. The output transistors for one of the channels are also shorted. They must be replaced along with every other bad component. If you miss just one of the bad components you will most likely burn up all the good parts you just put in. Resistors must be checked to make sure they are within the rated tolerance, capacitors must be checked for being shorted or being dry, diodes must be checked for being open or shorted, output transistors and driver transistors must be checked for being open or shorted, and the list goes on. It is a very difficult job for anybody not experienced in repairing electronics.
Take it to a reapir center that will work on those type of amplifiers, not all repair centers will.
I am very sorry to give you such bad news, but it is the problem you are having.
If you need any additonal help feel free to ask, if you decide you are going to try and fix it yourself I can tell you what to look for and how to check them, but without the proper equipment you will not be able to do this.
If you found this information helpful a rating of "FixYa" would be appreciated. The "FixYa" ratings is not just for helping you fix your equipment yourself, it is also for helping you decide if you can even fix it yourself or not.
Thanks, and I hope you find a good repair center.
Dave
Posted on Jun 28, 2008
Benimur
  • 6966 Answers
SOURCE: 700t trotter cybex treadmill
Hi again,
Appreciate the direct "Ask Me".
To your concern:
  • Error 1 - No speed signal at startup. This indicates that the controller board did not sense that the motor is turning. Procedures call for checking of the belt, the SCR (triac) controller (with an analog continuity tester), the presence of 130VDC spike/startup supply (with a voltmeter) and the brushes. Since you have replaced the brushes, the others then.
Of course the above requires familiarity with electronic components and circuitry, the use of an analog multimeter and possibly soldering. Should you be uncomfortable, then perhaps as you posted, "send the complete printed circuit to be check".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
FixinFax
  • 3085 Answers
SOURCE: fuse keep blowing
When a power supply fuse blows, it indicates that the bridge rectifier is defective.
Posted on Apr 01, 2010
Fuse keeps blowing immediately when switching on the treadmill, why does this keep happening?
A fuse is designed to prevent excessive current from flowing into a circuit. If the latter is not protected by the fuse, the excessive current can either cause some serious damage or the excessive current can overheat parts and perhaps result in a fire.
So, you are drawing too much current and that explains the small plume of smoke you experienced. If an electric motor runs slow because of excessive friction or load, it will use too much current, overheat and burn out the windings. Disconnect the motor and attempt to run the unit with the motor disencumbered. If the new fuse does not blow, then the problem is with the drive mechanism. If fuse blows, the problem is with the electronics and not the motor.
Aug 26, 2015 | Exercise & Fitness
I have a 2007 Toyota tacoma 4WD double cab my shifter lights my heater lights and tail lights keep blowing a fuse traced them all and there is no bad ground or any thing
do you have acell phone or other charger plugged in or multiple chargers?? i seen so many that draw way to much and keep blowing fuses. we've run several hot sockets direct from the battery to provide power for such dont forget to fuse it !
Mar 06, 2015 | 2007 Toyota Tacoma
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
What causes the 4 amp slo burning fuse to blow on a hobart beta mig 200
You are exceeding 4 amps? I have to believe this is a fuse for the control wiring and not the weld current or primary circuit. Likely you have a blown circuit board in the control area.
Sep 03, 2014 | Welding Tools
Fuse 18 for dash lights keep blowing. Have replaced light switch and instrument cluster
If your fuse blows repeatedly, the circuit is drawing
too much current. Possible causes:
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
May 06, 2013 | Rotora 2003 DODGE RAM 1500 PICKUP...
1992 gmc pickup keeps blowing heater fuses I replaced the blow motor and it keeps blowing
Have you replaced the blower resistor . some times they can cause the fuse to blow . You may need a muiltmeter to test the current draw on the blower motor circuit. the draw should be less then half of the rated fuse .( 20 amp fues draw is less then 10 amps) You did not say but does the blower work on high only or the lower speeds with out blowing the fuse ? if it does work on low or high with out blowing the fuse i would replace the blower resistor
Mar 06, 2011 | GMC Sierra 1500 Cars & Trucks
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
3 year old OTR microwave left on with nothing in it. now shows no power,board,lights or fan. what do I check first?
You have to open it up and see if you can find the power fuse, usually a BUSS 15amp Slo Blo that protects the Microwave Tube from drawing too much current and causing a fire. These fuses degrade over time or some get through that are not quite 15 amps and blow.
Dec 19, 2010 | Kenmore 69642 Microwave Oven
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet with 10g wire to its own 20amp circuit breaker?
check amp requirement on compressor info plate might need 30 amp outlet also if you have it plugged into long thin extension cord it will not turn fast enough cant get current it needs causing too much draw blowing fuse try plugging directly to outlet
Dec 26, 2009 | Air Tools & Compressors
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
52 people viewed this question
k24674
jasbo
jasbo
