I have a old Hotpoint washer(came with house) and 3 days ago the cold water side just ran to the tub and overflowed for like 7 hours(at work). The washer had worked fine before then. The hot water side was still on afyer I cut the cold off from the house and it did not run in tub but the cold would just keep running unless turned off at house faucet. So is the valve bad that the water lines screw into?
  • 135 Answers
Yes the valve will have to be replaced. This is a common problem as machines get older.
Thankyou for using Fixya.
Posted on Jan 24, 2009
Water won't stop coming in
There is a small clear hose that connects to the side of the tub near the bottom, the other end of the hose connects to a switch in the console behind the knob for the load size, this tube either came off while you were working on it or it got full of water. If it came off simply put back on but do so with the tub empty of water, this is very important!!
If the tube was filled with water, drain the tub and blow through the tube and reconnect.
May 01, 2010 | Washing Machines
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WATER IN TUB HOT, THEN TEMPERED
It sounds like you have an anti-scald mixer in the system that needs to be adjusted.
Jul 26, 2009 | Paini Spa Rubinetterie LaToscana 3 Piece...
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hotpoint washer will not stop filing with water
It would appear you have a faulty water inlet valve.
Try turning the water off to the washer. if it stops filling, then that is your problem
Replace valve or valves as required.
Please leave feedback
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
