Question about Motorola Mobility RAZR V3
Problem With Contacts List
I recently turned my phone off (which i rarely do, i usually just plug it into the charger at night) for a weekend. When I turned it back on yesterday, my speed dials had apparently been cleared, and i cant access the my contacts' information. All my contacts still show up on the list, but when i click on them to view or edit information, it takes me back to the home screen. Is there a way I can fix this problem, or at least restore the factory settings without clearing all my contacts?
  • 63 Answers
Hi There, You can possible try a master reset and see if this will solve your problem.If this doesn't work you can try a master clear. The master clear would erase your pictures and downloaded or bluetoothed music.The master reset will not. SAM !
Posted on Jul 13, 2007
SOURCE:
Why won't my sony ericsson t707 charge when the charger is plugged in???
first check whether your charger is ok, if it is working on another mobile, look for corrossion on the charging connector of your phone, if you see it corroded or clogged, power off your handset , remove battery and then clean the contacts with a pin or a small blade.
reinsert battery and try charging.
it should be working now.in a rare case if on connecting charger there is red light blinking and your set is not turning on you have a software crash and need to be updated at a service center.
regards
please comment
Jan 01, 2011 | Sony Ericsson T707 Cell Phone
Recent Contact List in Messaging is blank
I had this problem too. Found out that by shutting the phone off then turning it on again allows the 'Recent Contacts' list to build up again.
- Jon
Aug 28, 2009 | Samsung Jet S8000 Cell Phone
My Iphone wont turn on
my best guess is to plug it into itunes and hold down both the home and sleep buttons. this will put the phone into recovery mode and sadly has a very high chance of erasing everything on the phone. It, however, seems to be the only way to turn it on.
Jun 13, 2009 | Apple iPhone Smartphone
Kyocera wildcard dropped into water and flashes white screen
im unsure if theres a problem with the scree or you mightve gotten a shortage in the phone
May 29, 2009 | Kyocera wild card Cellular Phone
Ic502
Select contact, ( not from recent call list ) us softkey or menu to select "contacts" go to the contact name and press menu key and select edit. Scroll down until the phon number is highlighted and press the ok key. Make your changes and be sure to select "save".
Feb 09, 2009 | Nextel ic502 Car Charger
Motorola mts 2000 won't turn on
It is doubtful you ruined your battery, as they are designed to be left charging for periodic long periods, such as a full weekend, when a business is not open.
If you battery previously worked before charging it, I would suggest checking the connection to the radio, and the battery contacts on both the radio and the battery. It is possible you have flattened one of the contacts or some other contact problem.
If the battery did not recently work, it is possible it simply needs replaced.
Lastly, you might want to verify your charger is working. It is possible the battery did not get charged, and is completely dead. This is the least likely scenerio, as it is rare a battery is stone dead, unless it is no good.
Try a battery from a known good radio on the effected radio and make certain the radio is functional. If so, check the contacts, if okay, replace the bad battery.
Best regards.
Jan 12, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How do i delete send to-Recent contacts
you just go to "send message" option, then select "picture mail", then go to "recent list", click OK, then select the person you want to delete and click on "options" and click on "delete". It will then delete that person from your recent list. I just did this and it works.
Dec 08, 2008 | LG RUMOR Cellular Phone
Lost my Contact List and recent calls
well one time {i had the same fone}  my contacts started to scroll uncontrollably, like as soon as i was in "contacts" it just started scrolling down so i wen't to the verizon store and it said i had water damage so maybe that could be the case? Take the battery out of your fone and look at the little square on the back. If it is any color but purple {most likely green} that means ur fone has had water damage and that you will need it to get replaced.
Jun 02, 2008 | Samsung SCH-a870 Cellular Phone
PHONE TURNS OFF WHEN I CHARGE IT
Both of my e815's had this same problem. I was able to remidy it by taking a tooth pick and cleaning the contacts where the phone charger plugs into. Since I have done this neither one of my phones turns off when it is plugged it. Hope it works for you too!
Dec 10, 2006 | Motorola Mobility E815
Motorola Mobility RAZR V3 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
