Technika trove freeview box fault - Televison & Video
3 Suggested Answers
SOURCE: Resetting my TECHNIKA STB9007LE Freeview Receiver
Hi there
It appears that somebody at Technika thought it would be a wonderful wheeze to the box ask for a PIN when retuned. My daughter had the brainwave of putting in four zeros and voila!!!
Hope that solves your problem
Posted on Oct 02, 2009
  • 212 Answers
SOURCE: User manual for Technika freeview recrder box
You don't say what model it is! However, it's probably a vestel based unit so have a look at the following link. It is a manual for a different make but may well be the same as yours but a different brand.
http://www.grundig.co.uk/content/ug/GUSTB250IV.pdf?language=en-GB
Posted on Jan 13, 2010
Technika tv help line
check the settings in the tv setup menu, the AV ports can usually be configured for analogue or digital,
Dec 07, 2013 | Televison & Video
Hi I have two freeview boxes running from one aerial which split at a boooster box, one tv works fine, it the farthest away from the booster box, but the other has some channels freezing up and stuttering,...
The problem you describe is called "Digital Cliff Edge" and it's caused by signal loss. I wont go into the specifics of that at the moment as it's not going to help solve your problem. I you want more information about DCE, try an internet search.
As you are using the same aerial and booster/splitter for both TVs, you are correct in ruling these out as the cause of the problem. The fault is probably in the co-ax cables or connections but you might have a faulty freeview box. Please run through the following checks to establish the source of the fault.
1. Swap your Freeview Boxes - you shouldn't need to re-scan/tune as they are running off the same aerial..
If the Freeview box from the TV that is working correctly freezes and stutters on the other TV, the fault is probably in the cables or cable connections. Next, try the "faulty" Freeview box on the TV that is working correctly. If you get stuttering sound and freezing/pixellation you probably have a faulty Freeview box. DO NOT SWAP ANY CABLES FOR THIS TEST.
If the problem is the same after swapping the freeview boxes:
2. Swap any non-fixed cables, e.g the co-axial "fly-leads" and scart cables - one at a time. See if the fault "moves" with the swapped cables. "Fly leads" are the short co-ax cables that link the Freeview box to the TV or the TV to a wall mounted aerial socket. If the fault "moves" with the swapped cable, you have identified the source of the fault and should either repair or replace this cable.
Try these tests first and post back with the results. If you haven't identified the source of the fault, I will try to assist you further.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
Hi my mum has been given a dvd/video combi Technika DVR100 as her one does not record her progs while she is at work after the digital changeover.. question is will this record her progs which she watches...
You would have to connect the free view box to the vcr with a scart lead.Plug it into av2 on the vcr.To record select av2 on the vcr then set the channel on the freeview box.
Oct 16, 2010 | Televison & Video
Technika TV Tuning Problems
hi the same happened to mine. a22inch freeview dvd.wont pick up a signal when tuning in.Its had very little use ( 150hrs ish) as its in our caravan. we now plug in a separate freeview box via the scart.Tesco dont want to know as it was 3months out of warranty at the time of complaint.Anyway Im meeting Tesco in County court in july. It appears to be a common fault
May 13, 2010 | Televison & Video
Hi there
Sep 09, 2009 | Televison & Video
Freeview box with lost pin code
technika freeview box pin number
Aug 23, 2009 | Televison & Video
Freeview Box :(
This kind of interference can often be caused by remote pick up from energy saving lamps.
Mar 17, 2008 | Televison & Video
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
Nov 25, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
