Panasonic CT-32SL13 32" TV
Problem for Panasonic CT-32SL13 32" TV
The TV Will Not Turn On
By ron_estey on Jan 24, 2009
Where is the Main Power Fuse Located in a Panasonic Model CT-32-13G
Same Problem
Apr 29, 2009
-   I turned my TV on this morning, when I came home from work this evening, it will not turn on at all. Please help! -   dbeal2
Solution #1
posted on Jun 18, 2009
Not Rated)
jeffreyirish
Rank: Guide
Rating: 96%, 6 votes
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Was this helpful?
Yes
No
Popular Solutions for Panasonic CT-32SL13 32" TV
Questions and Unsolved Problems for Panasonic CT-32SL13 32" TV
Do you recommend Panasonic CT-32SL13 32" TV?
Answer
Answer
I have an old Sansui 29" TV Model SV 2902 R. I have lost my Remote Control during shifting. I... (More)
Answer
Philips tv turns off itself every now and then i am tired pleaase help.
Answer
Panasonic CT32SL13G 2003 - problem - tv won't turn on
Answer
Well bought this TV; (Panasonic CT-32SL13 32") a while ago off of a friend, worked great up... (More)
Answer
How to change the fuse on a panasonic CT-32SL13G - FixYa
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in San Mateo, CA
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
