Question about Nikon D2Hs Digital Camera
FEE I have reset the aperture ring at its lowest setting but no matter what happens I am stuck with the FEE thingy. Am I missing something?
    Genius:
  • 2,985 Answers
Explain - 'FEE' thingy? Coz I'm certainly missing something
Posted on Jul 10, 2007
SOURCE:
Focus repair af
I'm surprised it works at all at f/2.8. The FEE indicates that the aperture ring is not at its minimum setting (largest f/number).
Turn the aperture ring to its minimum setting. You should be able to control the aperture from the camera body, the same way as on a lens without an aperture ring.
Dec 13, 2013 | Tamron 28-105 F2.8 LD Lens
Error: FEE on Nikon AF N6006 film camera with Nikon lenses.
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
Feb 05, 2013 | Nikon Used N6006 AF 35mm SLR Autofocus...
Fee error on d300 with Sigma lens with aperture ring
Turn the aperture ring on the lens to its smallest setting (largest f/number) and then forget it's there. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Oct 13, 2012 | Nikon D300 Digital Camera
My Nikon F80 won't load y film automatically, it has a FEE error on the screen but i don't know what that is??
The lens you are using has the aperture ring set to something the camera cannot use. Simply turn the aperture ring to the largest number, usually a 22 or 32. Lock that ring if there is a lock and the fee should be gone.
Aug 31, 2012 | Nikon F80 35mm Film Camera
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
I've been reading all the messages and Im getting the same FEE code. It works while manualy putting it on the F22 aperature setting. But I was wondering why I can no longer manualy control my aperature...
Leave the aperture ring at f/22. You can then control the aperture from the camera body, the same way you would with a lens without an aperture ring.
Jan 05, 2011 | Nikon N65 35mm SLR Camera
FEE keeps flashing with aperture ring nikor lenses
Your aperture lenses should be set to the biggest f-stop (smallest aperture)
Jun 07, 2010 | Nikon D70s Digital Camera
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
What does it mean when FEE is in the view finder
FEE means that your lens is not set to the smallest aperture setting. If you are using your camera's auto-focus mode, the lens must be set to the smallest aperture setting which, on your lens, is probably f22 (the smallest aperture is the largest number). Once you set the lens aperture, you should slide the aperture lock to the locked position. The aperture lock is located just right of your largest setting f3.5. This slider should line up with the orange line. To verify that the latch is engaged, try to change the aperture by rotating the aperture ring. In the locked position, the ring will not turn.
Nov 28, 2008 | Nikon 2880AF F3.3-5.6G Zoom Nikkor,...
FEE blinks
Set f stop ring ( aperture ring ) on the lens to highest F stop number ( 16 ) and lock in position. This will get of fEE massage.
Jan 21, 2007 | Nikon N60 35mm SLR Camera
Nikon D2Hs Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
