Question about GN Netcom GN 9350 Wireless Headset
GN9350 speaker not working - GN Netcom GN 9350 Wireless Headset
Jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Aug 30, 2012 | Jabra GN9350e Wireless Headset
Jabra GN9350e - my voice echo's back to me but the user hears me fine, is there any way to change the feed back?
Here's what fixed it for me (running Windows 8.1 on a Surface Pro 3):
1. On your taskbar, right click on your volume control options (the little speaker icon), and choose "Recording Devices." ALTERNATIVE: You can also get there from Control Panel, searching for "sound" and selecting "change sound card settings," then go to the "recording" tab.
3. Right click on the GN9350 and select "Properties."
4. Go to the "Listen" tab.
5. Unclick the "Listen to this device" checkbox.
6. Save and exit.
Oct 28, 2010 | Jabra GN9350e Wireless Headset
Worked last week computer crashes now restored speakers don't work now. another set of speakers work. &35's won't work on a different computer, Powers up clicks when plugged in but no sound /
You said, other speakers worked fine ono that pc right? And the speakers doesn't on other computers? Then surely the speakers are now defective. It might be the wirings or internal parts of the speaker. Check warranty of the speakers, if it is expired, then you have to replace the speakers.
May 25, 2010 | Boston Acoustics BA735 Computer Speakers
Computer is not recgonizing my speakers?
Check the speakers with any other device. Probably the speakers are not working or if they work fine, connect any other working speaker to your system and check whether if they work or not.
If the other speakers also don't work you probably have a faulty port.
Mar 30, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
My GN9350 is not recognized at all under Windows 7 (it was however, under Vista)! Where do I find the drivers for a proper installation?
Early GN9350 models are not compatible with Windows 7. The usb audio device driver for Windows 7 requires signed drivers, but the original GN9350's are not compatible as the drivers are hardcoded in the firmware.
I was able to confirm this with Jabra support. The option they offered me was to send in my existing unit and they would replace it with a new (likely refurbished) newer model for $110. I've sent it in as that is still a lot less thana new unit.
Dec 09, 2009 | Jabra GN9350e Wireless Headset
Headset button will not lift receiver unless ringing
You should be able to press the button on the headset as many times as you like and the lifter will respond, whether the phone is ringing or not
Mar 24, 2009 | GN Netcom GN 9350 Wireless Headset
My Headset just stopped working on the gn9350 headset. The base is on but it does not seem to be charging and there is no light on the headset or in front on the charging station. Is there some way to...
Hi I was in a live session with you when you left. Apparently you have not paired the headset with the base. All you have to do is follow this procedure
Place the headset in the charging base->Press the base's pairing button->Both the telephone and USB buttons on the base until the headset's link indicator will light for 2 seconds indicating that the pairing is successful. It should probabl charge after this.
Let me know if you need more help.
Sai.
Mar 17, 2009 | GN Netcom GN 9350 Wireless Headset
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
My right control speaker doesn't work.
your speaker control cable is not working right try to push the cable in to the speaker a litte bit and then try.
May 13, 2007 | Harman Kardon HK595 Computer Speakers
GN Netcom GN 9350 Wireless Headset Logo
27 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
