Question about Bosch PowerStar AE3.4 AE3.4 Point-of-Use Electric Tankless Water Heater...
Water doesn't stay hot PowerStar AE3.4
Kitchen sink is all the way across the house from the water heater. Takes forever to get hot water. Put this unit under sink to cure wait. Water gets hot quickly, but after running water for a couple of minutes it is just tepid. Have reduced flow aerator to keep max flow rate in limits. Instructions say it can't be hooked into the hot water line. Why? Seems like that would cure both my problems. Unit will heat up water cooled in piping from water heater and than I get heated water from tank.
    New Friend:
    Problem Solver:
  • 9 Answers
Apparently the software in the brain of the unit is not capable to modulate for smaller heat need and it trigger off the unit when it only need less the 20F temp increase . That is a lack of engineering in the brand unit, and really can not be "fix"
Posted on Feb 02, 2013
Are you using a single lever faucet? The install guide does indicate that you may need to reduce the input from the cold water side to ensure that water stays at a consistent temperature (see page 7 of the installation and service manual). Also, remember, this is a SMALL hot water heater. So if you're running for any length of time at full output, it may not keep up with you (see page 8 of the service an installation manual). I found the manual online at http://www.airwater.biz/images_templ/bosch-water-heaters-ae3.4-manual.pdf.
Posted on Feb 01, 2009
Left red button has to be constantly reset. Also, water gets extremely hot
It should be producing hot water at the temp it was set at such as 120-140 degrees. If it is exceeding this one of the safety devices maybe disconnecting it. Thermal control might need some servicing. See what temp it's set at then put a thermometer on a near water outlet to see what's going on. Good luck.
Sep 06, 2015 | Bosch PowerStar AE125 AE125 Whole House...
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
We need to replace the 6 way terminal on our Powerstar A125 tankless hot water heater due to a loose wire that got hot and melted the terminal at the end. How do you do this. We have the part to rep
What happened to the screws from the old terminal strip?
If it is a different size you need to drill new small holes in the box (not the tank or pipes) and attach it with self tapping screws. Make sure each wire of the unit matches the same wire being connected as the original connections.
Jan 27, 2012 | Bosch PowerStar AE125 AE125 Whole House...
We have a bosch tankless water heater in a 1600 sq ft home...it works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
Aug 29, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Bosch PowerStar AE3.4 AE3.4 Point-of-Use Electric Tankless Water Heater... Logo
371 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
