Question about Vehicle Parts & Accessories
Viper remote start rpn 472v ezsdet474v wont work. Press remote start , lights flash , fuel pump gets power but vechicle wont turn over
2 Suggested Answers
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My car quite starting from viper remote :(
Does it power up (meaning do you see the dash light come on)? Does it turn the starter?
Dec 18, 2012 | Remote Start System
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
What other remote can i use for the 791xv
The original remote is the 479V; you can also use the 472V.
Oct 16, 2010 | 791XV The 791XV is a 2-way Security and...
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
Need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Jul 20, 2009 | Viper Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
