Question about Panasonic CT-32SL13 32" TV
Where Is The Fuse Located In A Panasonic CT-32SL-23G ?
The TV will Not Turn On
  • 7 Answers
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side on the bottom toward the front, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Posted on Jun 18, 2009
Want to know if panasonic tv CT-32G31 has a fuse...shut off and i am unable to turn it on
Yes! there is a fuse on the inside of the set, unplug set, remove back cover, and follow the power supply cord to the main board, fuse should be near by.
Mar 19, 2011 | Panasonic CT-32G31 TV
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Where is the fuse located on the panasonic model CT-32SC15N tv?
Usually on the power/deflection circuit board inside TV
Jan 07, 2010 | Panasonic CT-32SL14 32" TV
Hello, My Panasonic ct-36HL44 won't turn on. It's complestely dead. Yesterday and for the last 4 years---its been perfect, completely reliable. What happened? Is there a fuse inside the chassis and can I...
I had the exact same problem with this model a few months ago. Repairman came out to my house and told me that Panasonic is well aware of the problem but never issued a recall on it. He then charged me $150 to take off the back of the tv and replace a blown fuse with another fuse with a slightly higher voltage rating. Took him all of 5 minutes. He took off back of tv and the fuse is located, if you are standing at the back of the tv, on the bottom in the left hand corner. You can't miss it. I wish I could tell you which fuse he put in but I didnt see it. Sorry. Try it for yourself and you might be able to save $149.50, b/c I doubt that fuse cost much more then 50 cents. Good luck.
Mario in NY.
Dec 09, 2008 | Panasonic CT-36HL42 36" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Tv lock
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
Aug 26, 2008 | Panasonic CT-36SL13 32" TV
Won't turn on
it is located near of the ac cord (wire)
May 07, 2008 | Panasonic CT-36HL43 36" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
Panasonic CT-32SL13 32" TV Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
