Question about Brother HL-2040 Laser Printer
Paper feed stopped working when inserting a replacement carthrige
Paper feed worked fine until I inserted a new carthridge, HL-2040 brothers printer. After installing then reinstalling when paper feed quit working. Still will not work
  • randjohn2009 Jan 25, 2009
    After replacing the cartridge with the New One, paper start jaming.
    Even I have followed all the step to reset precisely.
    Anyone can help ?
    New Friend:
  • 114 Answers
Clean the drum , your problem will be solve.
Posted on Jan 31, 2009
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
Brother 2040 printer blinking paper light - I open all of the drawers, took out and put the cartridge back in, played with the paper wheels and it won't stop blinking!
Hello ,
This is due to your computer software selecting the manual feed instead of tray one usually because the software program decides that the paper size is not the standard letter size, such as envelopes, and has to go through the manual feed.
If you are having trouble finding the manual feed, it is found just above the paper tray, usually on the front panel of the printer.
If you are trying to print a letter sized document yet the printer still asks for the paper to be inserted into the manual feed, then one of the settings in the software you are using needs to be changed.
For most windows based applications, you can find a “page setup” menu; in this menu, there is a section that specifies the tray being used to print from.
Make sure the setting in page setup is set to “tray 1” and not “manual”
Thank you,
Mar 29, 2010 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Paper light on
You can try to hold on the Start buttom until you see 4 lights. This help the printer to reset the software, after that sould be working fine.
Apr 29, 2009 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Paper Jamb in Brother HL 2040 Printer
inside the printer their is a roller and if you turn the roller then it should feed the paper through it fairly easily. it may seem like you are turning really hard but it will work.
Nov 14, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother 2040
Broken carona wire in drum replace drum or non gen toner not working correctly
Nov 13, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
353 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
