Question about HP Laserjet Cp2025n Printer
HP CP2025 error 59.c0 - HP Laserjet Cp2025n Printer
  • 22 Answers
SOURCE: HP3550 59.c0 error
Right swing guide problem. Mechanical but complex. You'll need the manual.
Posted on Jul 06, 2008
cene765
  • 787 Answers
SOURCE: my printer clj 2840 displayed error code 59.c0
This mean a main motor error occurred. X description: 0 = Motor error 1 = Motor start up error 2 = Motor rotation error
1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Posted on Oct 16, 2009
SOURCE: hp color Laserjet 5550 59.C0 printer error message
hp_color_laserjet_5550_59_c0_printer
Posted on Feb 20, 2010
  • 75 Answers
SOURCE: 59 C0 error on hp color laserjet 5550
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Posted on May 10, 2010
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
Posted on Jul 22, 2010
Hp color LaserJet cp2025 59.c0 error how to fix it
59 errors indicate one of the motors have failed. It could be a bad motor but also a bad cartridge will overload a motor and cause the error as well. If you have spare cartridges, try changing them one at a time and restart between changes to see if the error goes away. Also if the error only happens when you start to print it might be the fuser motor.
Aug 27, 2015 | HP Office Equipment & Supplies
What is the 59 CO error?
59.C0 Developer motor rotation error
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If the problem continues, contact HP Customer Support Center for technical assistance
Sep 09, 2014 | HP CC377AABU Color Laserjet Cp1515n...
Its displaying an error code 59.c0 how can i solve this?
Error 59,c0: The developer-disengagement motor
experienced a rotational error.
1. Perform the Alienation Motor test in the
Component Tests menu in the
Troubleshooting menu. Verify that the
cartridges are being correctly alienated.
2. Check the following connectors: J25 at
the motor (M10), J261 and J251 on the
high voltage power supply-D PCA, and
connectors J138 and J106 on the DC
controller PCA.
3. Perform the Manual Sensor Test and
observe item G. The normal state is "0".
Locate the in-line connector J70 in the
cable that is connected to developinghome-
position sensor (SR11). To find
this connector, remove the left-side
cover and look in the area below the
support plate. Disconnect the in-line
connector. The state of item G should
change to "1".
4. If the motor is defective, replace motor
M10. If the sensor is defective, replace
the main-drive assembly
Apr 01, 2014 | HP CP3525N Color LaserJet Printer
Display showing error 59.C0 on Hp Colour lasejet 3600 printer
59.C0 ERROR
An error occurred with the developing separation-drive assembly.
1.Check that the following connectors on the driver PCA are seated correctly: J403, J405, J213.
2.Check that connector J1020 on the DC controller is seated correctly.
3.Check that connector J5008 on the fuser motor is seated correctly.
4.Replace the developing separation-drive assembly.
5.Replace the memory-controller PCA.
6.Replace the fuser.
Jul 11, 2011 | HP LaserJet 3600n Printer
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 10, 2011 | HP LaserJet 5550DN Printer
Laserjet 3700 got 59.C0 error
Figure 1: Right swing arm assemblye755e62.png
6349049.gif 1 - Part in place
2 - Part missing
i think it solves your problem
if you have any problem regarding this issue leave a feed back,we will glad to assist you
good luck
Sep 10, 2009 | HP LaserJet 3700dn Printer
HP Laserjet Cp2025n Printer Logo
676 people viewed this question
Seeker5211
Seeker5211
