Question about Refrigerators
Water freezes about once a week in water dispenser, I open door , use heat gun to warm door , water works for about a week or two, then it freezes again. Been doing this for about 6-8 months. Tried not having freezer so cold doesn't make a difference. Even tried having appliance store repairman look at it , all that gained was them charging me 100.00 to tell me what I told them.
  • 198 Answers
This appears to be an insulation problem, inside the freezer door. You will need to dis assemble the freezer door to reinsulate that area
Posted on Jan 24, 2009
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in door will not work
I need to know the make and model # to more accurately help you. First and foremost, you will need to thaw your holding tank with a steamer...do NOT use heat gun or hair dryers. The problem could be one of several but I would start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze. I've seen this with LG's and GE's. They make a special heater modification for units notorious for this latter problem.
Nov 25, 2008 | Refrigerators
Hotpoint HSS25GFP: No water coming out of my water dispenser
GE has an issue with the water line freezing in the door. Try turning dispenser light on for 24hours the heat it generates warms the line. Also GE has a heater kit available
Email me for Service Bulletin on Water lines freezing
amasuperbike@comcast.net
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
GE Refrigerator Water Not Dispensing
Had the same problem. No water to the dispenser. After removing the grate at foot of refrigerator was able to get water to bottom of tube. Careful with the funky little coupling, push the white ends inward to disconnect. Turned off refergerator for awhile and used a blow dryer to warm up the dispenser area from the outside. Be careful not to damage plastic by over heating. Also tried to warm the exterior of door but not sure if that helped. Used a hand activated vacuum pump on the water exit spout. Took a long time but evidently the water just prior to the spout had frozen. Had run a small metal wire up the tube from the bottom and it went nearly to the area of the dispenser so I don't think there had been any ice except at the area around the dispenser spout.
Hope this helps.
Dec 30, 2007 | Refrigerators
GE side by side water dispenser
Honestly the easiest way is to remove the door on a warm afternoon and put it in the sunlight for 2 hours or so there is no way to axcess it. Make sure that the line is frozen first by disconnecting the tube under the freezer door, close door, call for water it should come out in full force there. Have a shallow pan to catch the water. feel free to respond. thanks
Nov 16, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Oct 11, 2007 | GE GSH25JFR Side by Side Refrigerator
Water Dispenser freezes
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep if from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Jan 07, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
