Question about Ovens
My ikea oven fxtp6 failed to operate after a power cut
Bottom oven
Hello.
Put off the oven power from the main power supply from the wall the allow the oven relax it self for some plug the oven back to the power ,put on the power button then click on the reset button .
Please note if this fail then you need to troubleshoot the oven for the bottom oven operate better again.
Thanks.
Jan 03, 2012 | Ovens
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 | Ovens
Fan oven heats up then whole oven turns off, including timer.
It sounds like the thermal overload switch which is located in the oven cavity is operating and cutting the power. Does the power come back on once the oven has cooled down or is the power off indefinitely. Some thermal overloads are automatic reset and some are manual.
Feb 17, 2011 | Smeg Ovens
I replaced the flash timer on my oven and the power still does not come on what else could it be???
Is the electronic timer in the manual mode?
Is the element faulty?
Poor connection at the oven element terminals?
No voltage output from the oven thermostat control?
The oven thermal cut-out switch has operated and cut all power to oven?
Feb 08, 2011 | Frigidaire Ovens
Oven not warming up
The first thing to check is the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Although it may look o/k, the only way to be certain is to test it with a meter.
Hope this helps.
Jan 30, 2010 | AEG D2100-4 Electric Double Oven
Missing instruction manual for IKEA Whirlpool oven FC SM6
After a powerbrake the IKEA Whirlpooloven doesn´t work, the display just says STOP and nothing works, not even the light inside the oven. This always happens after a powerbrake and usually I can fix it after some time pressing different buttons but not today. Suggestions?
Dec 17, 2009 | Ovens
How do I set the clock on an IKEA oven?
Hold down the 'ok' button and it should be fairly self-explanatory from there.
Nov 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
Removing Whirlpool oven door.
My whirpool ikea single oven door is broke can it be replaced
Jun 26, 2008 | Ovens
Ovens Logo
196 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
