Question about Microsoft LifeCam VX-1000 Webcam
My lifecam problem
Hi my lifecam mic picks up a high pitched noise when recording or speaking to someone basicly all the time how do i fix this?
  • Anonymous Jan 28, 2009
    I have the same problem with my VX-1000.I thought that the microphone is damaged or something like that..but now I thing that is only a very poor quality one.
  • Anonymous Apr 22, 2009
    nemoze otvori Webcam video i slika?
    President:
  • 8,637 Answers
What it sounds like is that you are getting feedback from your speakers. Turn down the sound or try a set of headphones to see if that eliminates the problem.
Hope this helps. Bud
Posted on Jan 28, 2009
  • Weldon Dube'
    Weldon Dube' Feb 06, 2009
    Normal
    0
    Two
    things can cause high pitch noise and static.
    First,
    If you have your speakers turned up to high it will give you feedback causing
    distortion and static. I recommend using a headset when videoing.
    Second
    reason is, if you are using a laptop and have added an external microphone
    between the two it will cause distortion and static.
    Not
    knowing the configuration of your computer makes it harder to analyze the
    problem.
    So
    hope this is of some help. Bud
  • Weldon Dube'
    Weldon Dube' Feb 13, 2009
    Normal
    0
    Two
    things can cause static.
    First,
    Second
    Not
    problem.
    So
High pitched squeal from powerd speakers
Check to make sure the WIDEST blade of the AC power plug is actually the GROUND (as in "not HOT") in the new location!
Apr 30, 2017 | Peavey Audio Players & Recorders
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
Since installing Microsoft Lifecam VX3000, I have no sound on my computer or on the Lifecam
check your audio out
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 06, 2010 | Microsoft LifeCam VX-3000 Web Camera
Everything seems to be working, but the audio has a lot of noise when playing back? Robert
1) Make sure your webcam mic is set as default
Vista
TEST SPEAKERS
Restart computer
2) During the recording you may be picking up feedback from your speakers - try using a set of headphones
Jun 22, 2010 | Microsoft LifeCam VX-3000 Web Camera
Audio works, but lots of noise (hiss) in the audio
Some lifecams need additional software or specific browsers according to your OS
Visit the microsoft website - enter the details of your cam and check out the 'readme' link also 'breaking and known issues link'
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
It may even be feedback from the incoming voice being picked up on your mic - headphones would prove that.
Finally you may have a laptop with a built in mic - check this
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO SKYPE
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make the test call
Click 'Save'
Jan 14, 2010 | Microsoft LifeCam VX-3000 Web Camera
Adio capture is very low
check your basic audio settings
Vista
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Restart computer
Dec 14, 2009 | Microsoft LifeCam VX-3000 Web Camera
I try to record a voice message with lifecam vx-1000 but when I try to playback to check the message I don't hear anything. I have checked all the volumes & they're all fine. so why can't I record a...
Set up Audio example
Laptop x webcam/mic x Vista x Yahoo Messenger
TEST SPEAKERS
Restart computer
Dec 13, 2009 | Microsoft LifeCam VX-1000 Webcam
Problems with samson g track usb mic
sounds like your recording volume is too high, and its "clipping"
Mar 03, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
I get a humming sound when I record a video
There a quite a few reasons why this could happen.
  1. The sound device could be malfunctioning.
  2. The cables are not plugged in all the way.
  3. The camera may be close to a noise maker such as a fan, air conditioner, or your PC fan.
  4. The sound wires could be crossed with an electrical wire which sometimes creates static or a hum.
  5. If you are using a normal Microphone, there could be static on the port or connector.
  6. The record volume levels are too high, or mic boost has been enabled and is picking up extra sound.
I hope one of these examples helps to fix your problem, if it doesn't, please get back with me and we can try something else. Good luck!
May 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam VX-1000 Webcam Logo
154 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
