Question about LG 32LD450 32 In. LCD HDTV
Rgb picture off center
Connected pc to tv using rgb cable but the picture is off center to the right
enov8
  • 53 Answers
SOURCE: cant connect to pc
It high definition digital signal. You will need a HD cable not a vga (that is analog).
Check in you tv manual. It should give you options of what cable to use. May need the HDMI cable.
enov8
Posted on Mar 08, 2009
SOURCE: pc to tv
buy a video cable and a sond cable and connect them to the back where is says rgb pc.then tao input - rgb pc.
Posted on Jun 28, 2009
SOURCE: LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Posted on Jul 08, 2009
SOURCE: I Just connect My pc via 15 pin RGB cable to LG
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Posted on Aug 18, 2009
  • 30 Answers
SOURCE: connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Posted on Apr 06, 2010
How do i get a picture from laptop to tv i have connected r.g.b lead
I am not familiar with your tv but the normal process is to change press the button combinations on your laptop so it is outputing the picture and then change the tv input to RGB. (Most laptops use function and F7 to activate LCD output & Input button on TV remote to change to RGB mode.)
Check the VGA cable is fully connected at both ends.
Hope this helps.
Jan 31, 2012 | Acer Computers & Internet
I want to connect my computer to the pioneer sd-643hd5 tv so I can view movies, pictures etc; The tv only has pin connections, cable connection, s-video connection, and a RGB port for HDTV broadcasting....
depending on the connections available on your pc, you can get a vga to rgb cable fairly cheap but I am not sure on how good the quality will be, same with the s-video connection. vga connections on the pc are usually blue in colour, if you have dvi connection you can get a similar cable to do the job. Most computers will auto sense the tv if you connect the cables with the pc switched off, make sure you are on the right channel on the tv and the switch on the pc.
hope this helps
May 06, 2011 | Pioneer Televison & Video
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
Connecting pc
Did you change the input on your tv to the corresponding input that your RGB cable is connected to?
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
LG 32LD450 32 In. LCD HDTV Logo
114 people viewed this question
Computer Repairing
Computer Repairing
