Question about GE Profile DPSB620ECWW Electric Dryer
GE Profile Dryer - sensor problem
I have a DPSB620EC GE Profile electric dryer. When operating in "sensor" mode (e.g., select a profile, such as "delicates" and the dryer selects time and temperature), the machine runs for about 3 minutes, and stops with the "Clean Lint Filter" light illuminated. I have cleaned out the filter, cabinet, and exhaust hose to the end. Then I realized that in "non-sensor" mode (timed dry, where I select time and temperature), the machine will not stop. Any idea which of the five temperature sensors can cause this?
  • drkiker Jan 31, 2009
    I cleaned the sensor bars, which were right where you indicated they would be, but am still getting the same result. What is new is that I am now getting the error on timed dry also, but not every cycle. Any new ideas?
  • 1,543 Answers
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Feb 01, 2009
    It's hard to get a correct diagnosis when the symptoms change. I'm going to have to double my fee. (let's see now, free x 2 = ?)
    How long has this been happening? How long is the vent and how many turns are in your venting?
    One key thing you mentioned was "exhaust hose".
    Flex exhaust hose should be replaced with rigid aluminum pipe and elbows, and the outside vent should not be one of those kind where the flap can only move two inches. (should be a full four inch flap or several louvers) The flex stuff can get folded over or partially crushed behind the dryer and by elbows, reducing actual opening inside it to near nothing, and the ribs along the length of it restrict air flow and will catch and accumulate lint. If your dryer outlet does not exactlly line up with the vent in your wall, use a telescopic aluminum vent peice instead of flex there also. I also think I deserve better than only thanks for trying, even after I doubled the usual fee.
DPSB620EC1WW dryer, about 7 years old. Drum is making a terrible sqeeking sound when it turns. Can't see how to open the dryer to see what is up
Posted on Nov 07, 2009
Tip
GE Profile Harmony DPGT750EC (Electric)
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile electric dryer dpsb620ec ww
Did u reconnect wires to door switch, or maybe inadvertently pulled them loose.
Aug 24, 2017 | GE Profile DPSB620ECWW Electric Dryer
I have a GE profile dryer dpgt750 and it will not get hot only stay wsrm
you need to access the cycling switch and the sensors in the dryer heater/blower housing and possibly replace the drying sensor bars by the door on the unit
Oct 03, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile DPSB620ECWW Electric Dryer Logo
3,516 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
