I replaced the lamp 6 months ago and worked great. Now none of the fans run, and when I unplug it and plug it in to the wall there is no fast flashing timer light and I can turn the tv on right away. I turn the tv on and than I get the fans but no picture or sound. It stays on for a short bit and than powers itself off and the status light blinks normal(green) and than turns solid red. I did a self check and comes up code 34 witch is (lamp abnormal). This is on a wd52327 Mitubishi, it is about 3-4 years old. Can you help........Thanks
Thats a very common problem which means that the capacitors on the power PWB have most likely failed. You can get the repair kit which has the replacement Capacitors and step by step instructions with detailed pictures on how to do the repair . Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
I ordered the caps and had them installed. still nothing so I tried replacing the lamp ballast and still did the same thing with the same code. I read that if the color wheel dont work the tv will not work. I found a used light engine with the color wheel and installed that and now the tv works perfect. It ended up being the light engine with the color wheel.
