Question about Nikon D100 Digital Camera
Nikon D100 When I take a shot and try to review the photo I get the message "Folder contains no photographs". The camera was disassembled to add an IR filter. I was extremely careful using a wrist strap and pad. I followed all the rule to avoid a static charge. Followed all the disassemble rules and was very careful. Is it possible I have a software problem. I went thru the manual and did all the troubleshooting procedures,,,reset, etc.......appreciate any advice. JohnK
  • Achena222 Feb 16, 2009
    We face the same problem "Folder contains no photographs" message.  I heard someone can still retrieve the photos with one software, but I'm not sure what software it is.  Please help.
    -Ach
5 Suggested Answers
  • 14 Answers
SOURCE: Nikon D100: Lazy mirror return.
The reason the mirror is acting up is because the Shutter is going bad under slow shutter speeds. > The motor which drives the shutter charge and the mirror up and down is the same .
Posted on Apr 11, 2009
SOURCE: Nikon d100 locked
Have you tried to reset the camera? I seen this a few times .. and the camera reset did the trick. I've never heard of the motor noise though.
Posted on Jun 26, 2009
  • 181 Answers
SOURCE: Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Posted on Jan 04, 2010
  • 411 Answers
SOURCE: Nikon L16 screen went white after just 1 day of usage
it is problem of C.C.D, replace with a new one
Posted on Mar 02, 2010
Hi, i took a series of shots nothing on card
Maye they were accidentally saved to the internal memory and not the card?
approved cards follow:
http://support.nikonusa.com/app/answers/detail/a_id/6/kw/d100/r_id/116678
The following is a brochure for your camera from the digital archives:
http://imaging.nikon.com/products/imaging/lineup/digitalcamera/slr/d100/index.htm
originally the camera had the following storage specifications: CompactFlash™ (CF) Card (Type I/II) and 512MB/1GB Microdrive™
If there is an internal memory, then sometimes the memory holds the pictures you took, and not the external memory card.
Jul 29, 2010 | Nikon D100 Digital Camera
D100 black image after photo is taken
Have you accidentally turned off "review"? You can also go to "reset" in the menu and try that.
Sep 17, 2009 | Nikon D100 Digital Camera
Camera doesn't focus very well on dark subjects.
I think you have 2 problems at one time.
1 - I notice that your depth of field is very narrow, (your aperature is quite open) which hardly can focus the spot you want. try to increase the f/number like f/4 or above. the models face and there clothes toward your nikon D100 is almost the same distance, so they should be in the same focus range, but as I said witch big aperatures like f/2.8 of f/1.4 every inch count when it becames to focus.
2 - Set your camera in Single-focus (not Continous focus) en focus on the models face. then press halfway en keep it pressed. then you can compose a new position (still pressed halfway) and when the composition is good, then press it further to capture the photo.
Jul 02, 2009 | Opteka HD² for Nikon D80, D70s, D70, D50,...
FOR error message when inserting a memory card with photos
You should try some photo recovery software to rescue the files on your digital memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
May 31, 2009 | Nikon D100 Digital Camera
Apr 07, 2009 | Nikon D100 Digital Camera
How to display my subject that im shooting on the screen i have a nikon d100
The D100 does not have a Live View capability. The screen can be used for menus and image reviews, not previews.
Mar 06, 2009 | Nikon D100 Digital Camera
Nikon D100 Manual shooting help
The mode dial (topside left) must be set to M. That's it for manual settings - the camera won't check anything, and certainly shouldn't require the flash. You need to choose your own shutter speed and aperture settings to get a good photo, but the camera will let you take a picture no matter how you have it set.
Feb 01, 2009 | Nikon D100 Digital Camera
Nikon D100 while shooting F--- appears and camera will not work
I had similar problem with D80 try removing the lens and cleaning the contacts. that seemd to work well for me.
Oct 15, 2008 | Nikon D100 Digital Camera
My D100 will not accept CF cards
You can always try the reset button. It is under the flap where the USB/Video out/ and power connector is. It is just above the power connector.
Oct 01, 2008 | Nikon D100 Digital Camera
D100 showing double images
I had the same issue and was directed to page 87 of owners manual. Chances are good that you have white balance bracketing on. This produces two images and can be turned off with the bracket(BKT) button and or CSM menu F11 WB Bracketing.
Aug 10, 2008 | Nikon D100 Digital Camera
Nikon D100 Digital Camera Logo
87 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
