Sceptre X405BV-FHD3 40 in. LCD HDTV Logo
Posted on Jan 16, 2013
The bottom stand will not come out.
I removed all four screws but the bottom will not come out. How do i get this out?
Anonymous
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 12 Answers
  • Posted on Jan 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Night Owl:
Answers
12
Questions
0
Helped
7313
Points
26
Some stands even if the screws are removed won't come out just because it's shaped in a way that it is retained by the rear plastic cover. So unless the last one is removed, the stand won't come out.
And make sure the stand doesn't get loose and falls on your toes when you remove the big back cover.
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    TH-C4HD18
    the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
    28helpful
    2answers
    I can't remove the stand off the tv
    Hi, i have instruction on removing your base stand.
    Removing the Pedestal Stand
    1) Carefully lay the front of the unit face down on a flat,
    cushioned surface such as a quilt or blanket. Leave the stand
    protruding over the edge of the surface.
    Note: Extreme care should always be used when removing
    the pedestal stand to avoid damage to the LCD panel.
    2) Remove the jack pack cover on the back of the TV to expose
    the pedestal stand screws. The jack pack cover can be removed
    without tools.
    3) Remove the four screws shown in the diagram below. This will
    allow removal of the pedestal stand.
    4) Once you have removed all four screws holding the pedestal
    stand in place, remove the pedestal stand from the TV by
    sliding the pedestal stand away from the TV.
    How can i get the stand off of the tv to hang on the wall?
    Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
    With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
    If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
    How do you remove the bottom mount from an lcd samsung so that it can be wall mounted?
    Page 85 of the manual has it, and can be downloaded here.
    Here's what it says to do:
    1. Place the TV face down on a soft cloth or cushion on a table.
    2. Remove four screws from the back of the TV.
    3. Separate the stand from the TV.
    4. Cover the bottom hole with a cap.
    There is a picture in the manual that indicates that the four mentioned screws are the four on the bottom back of the television.
    5helpful
    Stand wont come off grundig tv model gu19wdvd3 to mount it
    Remove the three screws from the back of the stand.
    Remove the four screws from the bottom of the stand.
    Looking down at the bottom of the stand, push the four protuding clips inwards (not easy - you may need to gently ease them with a small screwdriver)
    This unclips the oval base and allows you to unscrew the remaining screw inside the stem of the base
    4helpful
    4answers
    I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
    With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
    1helpful
    2answers
    Removing the stand on Insignia LCD 26F TV
    My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
    Remove swivel stand
    There's likely a plastic cover on the back of the swivel stand. If so, remove it and you will find four to eight phillips screws. Take them out and the stand should come free. If there is no plastic cover, then there should be some screws in the back cover that go through the back cover and into the support. Remove the screws and gently remove the stand. Good luck. David
    17helpful
    6answers
    Remove base of Insignia ns-ltdvd26-09
    to remove base from insignia tv
    1)remove plastic cover from bottom rear of tv
    2)remove 8 philips head screws on rear of tv above base
    3)pick up tv and base will come off
    once you remove it you realize how easy it is
    Top Sceptre Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
