Question about Transcend T.sonic 610 MP3 Player
Autorun not executing
My t.sonic610 1gb mp3 player com pen drive is showing a used space of 229 mb out of available 949 mb. even when completely empty........also when i double click on the drive icon nothing happens...i need to use the explore option to explore the pen drive....nd copy.exe nd host.exe always are infected with virus...everytime i use the drive to transfer files they reappear.pls help me...thnx in advance.
  • 8,596 Answers
Every mp3 player has some space taken up by the native software, so it always shows less than advertised
Posted on May 23, 2008
SOURCE:
Not able to format 4 GB pendrive
your computer is infected with Autorun virus
you can solve your problem by two ways.
(1) go to view option in control panel then view tick the show hidden file click apply now insert your pendrive open it you a file present in your pendrive
select it go to properties and in attributes tick read only and nothing else now open notepad
write few lines that show
[Autorun]
Label=remove
Icon=ico
save it as Autorun.inf copy it and replace in your pendrive.
(2) IF the above method is fail use malwarebytes
To download click here or go to
http://www.malwarebytes.org/
Nov 19, 2009 | Pen Drive IVO MP3 Player
On inserting the pen drive,its showing that no disk is inserted into H drive.And on seeing the properties of the pen drive,its showing Zero MB free and Zero MB in use.Its not even being formatted or...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 07, 2009 | Pen Drive IVO MP3 Player
Can't format pen drive
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format pen drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 25, 2009 | iLO (2 GB) MP3 Player
Can't Delete Files From Global MP3 Player with Mac OSX
When moving an item to the trash, it actually is just in a hidden ".Trash" folder on that disk, so no space is actually freed up. Can you try hooking the drive back up and then emptying the trash?
Jan 18, 2009 | Global Marketing Partners V3-8B512G (512...
Pendrive error
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
I
Dec 02, 2008 | Pen Drive IVO MP3 Player
Pen drive not working
Try this - Start -> Run -> G: or H: (Your drive). If it opens then your pen drive has got a virus autorun.ini
Aug 14, 2008 | Pen Drive IVO MP3 Player
1 gb mp3 player not working
Same thing happened to me. I was using windows media player to sync my song and it says my player was using 260 mb of space even though it was formatted time after time. I simply loaded as many song as I could fit on the player. When I unplugged it and plugged it back in, windows media now showed that missing 260 mb of space as available. The only catch is that the song I had already uploaded on to the player were not shown on the sync list.
Aug 01, 2007 | iLO MP3 Player
Memoryproblem
Try creating a new or extended partition in the unused space using a later version of Partition Magic (www.download.com)This problem usually occurs due to a previous format not completing correctly IE the MP3 player was removed from the USB source before completing a previous format. Check to see that there is not a pinhole reset button on your MP3 player (requiring a paperclip or pen to be inserted into the pinhole and pressed until a factory reset of the device completes) Much like resetting a digital watch)once reset to factory you can attempt to format the device fully again.
May 17, 2007 | Sony NW-E405 MP3 Player
No space left even though all files deleted
format your player but make a back up of your music.
Aug 31, 2006 | Lexar LDP-400 MP3 Player
Problem in pen drive/mp3 player capacity
when you hook it up to the puter, go into My computer right click on the removable drive then click on explore disc and see what oter types of files are taking up the extra memory as if there are none then the drive has bad memory cells.
Apr 28, 2006 | Sony NW-E405 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
Top Transcend Audio Players & Recorders Experts
k24674
Chris
Parshiv Luthra
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
