Question about Chicago Pneumatic CP864 Dual Action Air Sander
Runs all time - Chicago Pneumatic CP864 Dual Action Air Sander
Fan belt continues to run the whole time I'm driving. 2008 Dodge charger the car isn't running hot either.
Your fan belt should run the entire time your are driving....(if you mean the fan runs the entire time... its ok too).. and your car should not run hot...
Sep 30, 2017 | Dodge Cars & Trucks
Rain bird e-6c on program a, 4 zones, when on auto is completed run does not shut off but starts over on the next run. Controller is set up as per instructions.
Check to see what time the other run is set up for. If the time is within the normal run time for the first run, it will start the second run when the first is completed.
Aug 25, 2017 | Cars & Trucks
This fidge is always running and for long periods of times. What is the average run cycle on a fridge for time??
the time is irrelevant. the running time depends on the thermostat setting To low a setting and the motor will run continuously, in the fridge and if the door seals are any good
Is the door being properly closed or left just not quite closed
How long and how many times is the door opened . run a series of checks before you get a technician out as most problems are "hand " made
Mar 25, 2015 | Refrigerators
I just bought a stopwatch to time myself running. How do I use it?
Hold the stopwatch in one hand and use your thumb to press down a few times until you have cleared the previous time. Once the stopwatch is reset, you are ready to use it. When you are ready to start running, press the button and the top down with your thumb. When you have finished press it again and the time it shows is your timed run. Repeat the steps when you are ready to time your next run.
Aug 20, 2012 | Exercise & Fitness
Dont no how to use my mega 450 delay box had it install but do not no how to set up during elimination at lights they tell me to but my time in on box for both sides n let go on buttom when other driver...
Bracket racing is trying to run the same time, time after time. Running agaist some one faster or slower. So say you run 10.90 they run 9.90 you need to start 1 full second ahead of him and not try to hurry when you see him catching up. You need to dial in your start time when he stages. which in a case like this you just punch and go on the .4 or .5 sec. if you running against some one slower than you you dial in then difference in time if your running 9.90's they running 11.90's you dial in 2 second of delay on his stage or who ever hits the lights last. Keep the same delay or jump the light. Always dial in a bit less than your fastest time, that way you never break out.
Jun 28, 2010 | 1999 Ford Mustang Cobra
Barely runs , timing retarded , only runs when est bypassed
You have set the timing to zero right? Then after you hook the bypass back up what does the timing go to?
May 24, 2009 | 1991 GMC K2500
Day time running lamps
The day time running lamps are your headlights, the parking lights also conventionally known as the running lights serve no purpose during daylight hours and as such are not necessary in the daytime, and are not illuminated by the DRL module. The DRL (Daytime Running Lights) module illuminates the headlamps in a slightly dimmer state than night time dim headlamps, but does not turn on the conventional running lights. The only way you'll get conventional running lights during the day is to turn them on manually. I just reviewed the wiring schematics for that system, and the DRL relay bypasses the dimmer switch when active and prevents high beam operation, and feeds current directly to the low beam headlights, there is no connection to the parking light circuit from the DRL module wiring.
Nov 01, 2008 | 2000 GMC Sierra
Chicago Pneumatic CP864 Dual Action Air Sander Logo
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
