Question about Kyocera Duramax sprint
Red cross on my duramax screen - Kyocera Duramax sprint
Bb 8520 comes up with charging sign with a red cross across on the screen. help!!!! Options
it happens when ur bb battery is damaged if u change ur battery u will not face that problem
Feb 13, 2013 | RIM BlackBerry Curve 8520 Smartphone
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
I have a red reflection on my screen. I heard it called convergence. How do fix it? It is 4300 series
Go into your main menu and scroll down to picture. Next scroll down to convergence press select. A white cross should appear on your screen the object is to converge all the crosses into one untill all the crosses appear as one white cross. The onscreen directions will tell you exactly how to do this. Next press continue and several little white crosses will appear across your screen. Do the same for each one of these white crosses. This should solve your problem.
Aug 14, 2010 | Apex Digital GB4308 43" Rear Projection...
My ipod classic 80gb just comes up with a red cross on the screen when i turn it on, i have tried putting it into manual disc mode but nothing happen.
red cross? I have had unhappy faces on my ipod, but not a red cross. Hmmn, my best bet is that the software is corrupt. Try restoring the iPod and see if that works.
Feb 17, 2010 | Apple iPod classic MP3 Player
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red crossed horizontal icon flashes on screen
It's the warning to replace the backup battery which is housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Calibrate touch screen
Actually, the red cross's movement is part of the calibration. Continue clicking each individual red cross until you get a confirmation notion notice.
In order to calibrate the touch screen, the DS needs to know where certain areas of the touch screen are relative to the actual display. Basically, you're not really controlling the display. You are interacting with a hidden interface, which is the touch screen. But in order for you to "interact" with what you are seeing, the touch screen is laid across the display.
Dec 07, 2008 | Nintendo DS Console
Kyocera Duramax sprint Logo
115 people viewed this question
Top Kyocera Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Kyocera Radio Communication Expert? Answer questions, earn points and help others
