Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Flashing f - 05
Hello, i have a hotpoint wd860 and i have an problem in my cycle and now it is flashing f- 05 can you help me please
  • leeoddjobs Feb 18, 2009
    yesterday mine had the same thing flashing so i cleaned out the tube to the drum. today it is flashing F-04 and stopping mid cycle
Hotpoint ultima wd860 made dreadful racket mid cycle then stopped displaying F04
Bernadette Fardoe
Posted on Feb 17, 2009
    done the above, now flashing F-04 but still no better
  • 135 Answers
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Posted on Jan 24, 2009
Hotpoint WT640 - it's flashing f-05. I emptied the machine and put on another wash and it says the same thing halfway through the cycle?
F-05 normally relates to the pressure switch,which normally points to a blockage.Does the machine empty slowly if so I would check the drain pipe first and if that is ok then you need to look down at the drain pump which may have a blockage in the filter which is inside the sump pipe,this is the main hose from the base of the drum and goes to the pump.
Hope this helps.
Aug 09, 2010 | Hotpoint Washing Machines
Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
MY HOTPOINT WD860 WASHING ACHINE HAS FLASHED F 05 DOES ANYONE KNOW THIS PROBLEM CODE.THANKS
F05 indicates that pressure switch is jammed on full.
Remove lower rear panel of washer, and locate and remove large black hose on bottom of drum, remove and clean filter inside of hose.
Please rate my solution.
Thanks.
Aug 30, 2009 | Washing Machines
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Sep 25, 2008 | Washing Machines
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
1,425 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
