Question about Bissell Vacuums
My hoover wont stand up
It doesnt seem to stand up on its own it just falls down
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
Dyson Rollerball wont clikc into unpright position.
I've just had the same problem! The small metal poles either side of the red push bar at the bottom of the hoover should both be in a groove/runner. The problem is that one or both of the metal poles has popped out of the runner and is stuck in one of the holes next to the runners. Gently pull the red bar from the hoover and pop the metal attachment back into the groove. Problem solved :)
Mar 30, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
After hoovering yesterday my dyson ball wont stand up right.
solved this today by folding the upright part back as far as it would go, and wiggling it a little. It clicked back into place.
Oct 11, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
It does not stand up straight
the plastic locking mechanism to keep it upright is broken. It can be fixed, but not sure it is worth fixing. I know its a pain to lean it up against the wall all the time, but the cost for replacing the part is not worth the expense in my opinion. Good luck!
Jul 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Open Questions:
Vacuums Logo
52 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
