Question about Mitsubishi Heating & Cooling
PAC-YT51CRB OPERATION MANUAL - Mitsubishi Heating & Cooling
Tip
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Air conditioner Pinguino PAC CT110 DeLonghi. I need the manual for the owner. THANKS
Try with this site;
www.manualnguide.com/manual/delonghi-pinguino-portable-air-conditioner-manual-pac-ct110/ -
Helpful?
Dec 29, 2010 | Heating & Cooling
Can't make model #63-3006 work
Hello there: it sounds like to me you have a wire that has came loose between the power pac and the board here is a link that might help you out a little bit ok? best regards michael
Home Use - Activities - Bounty Hunter Metal Detectors Bounty Hunter allows you to download the instruction and operation manual for each machine. ... Bounty Hunter Jr. Camo-LS. Guardian. Bud Jr. Page 1. Page
Aug 23, 2009 | Bounty Hunter Digger Metal Detector
DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
