Question about LXE MX7
Fpga load failed - LXE MX7
Facebook give me lot of error when i get out of a game on facebook many windows open and i can't close them
Try using a different web browser
like Firefox or Google Chrome.You
can get them INSTALLED over at the
link below. Good luck:
Ninite Install or Update Multiple Apps at Once
Nov 08, 2014 | Facebook Apps
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
My samsung washing machine SWF P10 front loader got its control card damaged due to a voltage surge.The company said that this card is no longer available with them;visual inspection shows charring of the...
Chip level repair can only solve the problem, Unfortunately, no one is available to do so. I have the same problem. The Samsung service people further cooked the card (PCB). Initially it was only flickering while running, now it shows all red lights and does nothing.
Sep 01, 2011 | Washing Machines
Have an error: security PAL not detected on a IBM 4400 printer
How do I fix a FPGA error on a 4400 thermal printer?
Dec 16, 2010 | IBM 4400 Thermal Printer
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Action Replay DS - "Load Failed" Error
Have you tried re-installing the Action Replay Code Manager through the disc? I find that re-installation works for most computer programs when the first-time-installation fails. Just choose the most recommended settings (don't do manual stuff) and try again. If it still does not work:
-Check to see if your internet is connected properly
-Check the disc for any scratches; Scratches on the top of the disc are LETHAL to memory!
Jul 21, 2008 | Nintendo DS Lite Console
Troubles during the upgrad from V2 to V3
Hi Louna_st
There are apparaently some hardware upgrades to be done also to get the v2-v3 upgrade to work. try the following procedure to get the unit back to v2 again and at least get it operating.
To reload v2 turn off the MC-12. Hold down the four buttons in the middle column of the middle zone on the front panel and turn the MC-12 back on from the rear panel. Keep holding the buttons down until the Lexicon says 'waiting for download' on the front panel. When it is like that you should be able to reload v2.
Fiber path not being found.
Have you checked the optical connections for dirt? Have you tried cleaning the optical connections? Did you do that correctly? Many people don't know there is a correct way and a wrong way. If you have any doubts about cleaning the connectors let me know and I will give a link to how to do it correctly. Do not use "Dust Off". You'll damage the connectors.
Apr 03, 2007 | Antares P-1055 (P1055) Network Adapter
LXE MX7 Logo
380 people viewed this question
Top LXE Computers & Internet Experts
David Payne
David Payne
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
