Question about Olympus EVOLT E-500 Digital Camera
Power switch is loose, not making good contact
It seems that the power switch on my e-500 is loose, or otherwise not making good contact. The camera turns on and functions normally only after pressure is applied to the mode dial, directly over the power switch. Anyone ever hear of this before, or have any idea how to service this?? Any help is much appreciated, and if you have any info please send a copy to davidks107@msn.com. Thanks! -David
    Genius:
  • 2,985 Answers
E 500 - not very old- Warranty job I should imagine I first instance contact Olympus Tech Support You may have to return to Oly or the seller.
Posted on Jul 10, 2007
Orion remote stopped working
clean contacts battery very well with isopropyl alcohol .
test the power of battery and replace put some from maximun energy.
3) see if there are some power loose or colder joint and resolder you must open the remote control.
However make test with the photo attched use camera, or cell and remote control, the LED must be on from remote control otherwise proceed with the steps before mentioned337cdc73-b1b7-4f0b-a2bb-46bf9a5cf9b4.jpg
God bless you
Jun 07, 2013 | RCA Televison & Video
What causes battery to be drained on 97 honda ACE 1100? seems it may be the starter switch on the handlebar but I am not sure that connection would drain the battery. The switch, over the past couple of...
At this point sounds like just the loose connection to the battery. What you need to do is check with a volt meter to see if it is charging its a simple test if you have a volt ohm meter or just take it to your local shop depending where your battery is located it a very quick check to determine if you have a charging problem.
As for the handle bar switch start button there is some carbon built up on the contact use contact cleaner for this.
Otherwise looks like your good to go
May 25, 2010 | Honda VT 1100 C Shadow Motorcycles
My batteries are full but camera won't switch on, it's dead!!!
It might be a problem with one of the switches at either the battery or flash card door.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try.
Sep 26, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Sony DSC 500 doesnt start when i want to.
Have you tried cleaning the battery contacts inside the camera? The problem that you describe is frequently due to a corrosion buildup that prevents the full power of the batteries from flowing to the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cleaning clears the problem about 90% of the time, and I hope it works for you.
Sep 19, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Olympus SP-500Uz won't power up. batteries have been replaced
Check the Batterys again and the contacts inside the Battery Compartment. Make sure you got good Batterys......Are they in correctly ?
Sep 15, 2009 | Olympus SP-500 UZ Digital Camera
Power switch
Make sure you are using a fully charged Nikon battery. Problems may sometimes happen with generic batteries. If you are using a Nikon batt, then seems you may need to bring this in for servicing
NOTE: Please rate our help to keep this free service online
May 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens won't open
low battery, battery not making good contact, else it is repair
Mar 16, 2009 | Olympus FE-230 Digital Camera
I have a canon Power Shot S50. The mechanical slider that covers the lens is loose. When I open it, it doesn't power up the camera. I suspect there is a switch underneath the cover is broken.
The open door button on a circuit board is usually micro. A loose cover will likely not make contact with this small switch. Take the cover off and tighten the screws on the inside. Try to locate the switch to inspect if it has been wore off, broken, or missing even.
Nov 13, 2008 | Canon Cameras
Fellows Powershred OS-11Cs - not working
It's just the (On and Off) switch not working properly (loose contact). Try to disassemble it and take a look if it's in the center location to make contact with On or Off positions.
Sep 09, 2008 | Fellowes 3011001 Shredder
Achiever ccs 5000 no power at all
hi check these before enything: 1) check with another device that the socket has power 2) check cable is good all the way (NOT torn, twiched, squashed) 3) the device is hooked up good (in place,NO trash) 4) there is a micro switch on the door which wont let the device work without no good connection 5) check good fuse should work good luck
Apr 05, 2006 | Achiever CCS5000 Shredder
Olympus EVOLT E-500 Digital Camera Logo
93 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
