Setting up wireless internet
I have a cisnet computer and i am setting up a wireless modem. I could not find the enthranet outlet on the back of the computer. Can you help me
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Are you connecting the modem to the computer using wireless or do you have a Wireless ISP(WISP)? In either case the ethernet jack on the back of your computer is usually located near the USB ports. If its an older PC then it may be near the bottom where the expansion slots are.
Posted on Jan 24, 2009
How to set up D-Link router
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Feb 08, 2012 | D-Link Computers & Internet
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
How do i initially install the sbg901 wireless cable modem
Locate the MAC id number on the modem. May be called the HRC mac id. Write this number down.
Connect the modem to an active cable outlet with a coax cable (the type that you would screw into the back of your tv).
Connect your computer to the modem with an Ethernet cable.
Connect the power cord and plug it into a power outlet.
Turn your computer on.
Call your cable provider and choose the options for tech support for internet.
They will need that MAC id number and then they should be able to set it up on your account and allow access to the internet.
Feb 12, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
I cannot connnect wirelessly with my linksys e1000 router and was told by their experts that my hp pavilion entertainment pc needed an update for the driver of my wireless adapter. I did go to hp website...
Check the following steps to connect wireless linksys router :
First, you have to connect the router to the ADSL or the cable modem.
Your system has to be set in such a way that it will get its TCP/IP network settings from the router via DHCP.
Second, you need to configure the router to use your Internet service.
Connect the antennas to the Linksys wireless router. Connect an Ethernet cable to the Internet port at the back of the Linksys router and it will establish a connection between your modem and router.
Connect another Ethernet cable between the computer and the router. Then connect the router to an electrical outlet.
Dec 04, 2010 | HP Computers & Internet
How do i connect a netgear wireless router to comcast modem
Unplug your Comcast modem from your electrical outlet. Connect the Ethernet cord from the back of your Comcast modem into the Ethernet port labeled "Internet" on your new router. Connect an available Ethernet port from the back of the new router to the Ethernet port on the back of your computer.
Plug your cable modem into an electrical outlet. Plug your new router in an electrical outlet.
Reboot your computer. Click on "Start," then "Control panel." Click "Network and sharing." Select "Set up a new home network."
Click on the option for a router or cable modem when prompted by Windows to select your hardware. Your computer will attempt to access your new router. When the brand name for your router is listed, double-click it so your computer can configure itself to the new router.
Create a new name for your home network and create a unique password to prevent unauthorized users on your network. Your computer may reset your Comcast modem and router so your new changes can take effect.
Nov 04, 2010 | Computers & Internet
Router won't broadcast
Use your computer's web-browser to connect to the web-server "inside" the router.
Check the 'WAN' settings -- they seem to be OK, since you have Internet access.
Check the 'Wireless' settings, or just rerun the Wireless Configuration Wizard, to rebuild your wireless network.
Apr 24, 2010 | Linksys Wireless-G WRT54G Router
My Linksys WRT54G Will Not Work.
It seems that your cabling is wrong. This is what it should look like:
  1. Telephone outlet to cable modem (Via telephone cable)
  2. Cable modem to router (via Ethernet cable)
  3. router via Ethernet cable or wireless to computers
Does your setup look like this? Please let me know if not so we can configure it correctly.
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from to save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
