Question about Taylor 1525 Wireless IndoorOutdoor Thermometer With Hygrometer
My taylor 1525 thermometer does not display or not working
I only change the batteries. it doesnt work anymore.
    Novelist:
  • 180 Answers
I've just been through this with my Taylor. My first mistake is that I put the batteries in the wrong direction... I corrected that and it only worked for a short time, then quit.. Ultimately, I had to get my multi-meter out. I found that one of my batteries was faulty.. Now, you have to remember that there are two AAA batteries in the main unit... and two of them in the remote that you place outside... Go.. You can fix it...
Posted on Jan 16, 2013
Taylor scale model 7004 v1812 displays ee replaced battery and it still displays we
Found in a 2012 FIXYA post for a Taylor 7558 but this may work for you too!
"...make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works!" More on this later...
Taylor 7558 scale not working even with new batteries
More...
The e on CR2032e denotes the manufacturer as Mitsubishi. Both are CR2032 batteries which means they produce 3V and 210 mAh (210 is the spec, 220 is a common claimed total energy content).
https://www.quora.com/Whats-the-difference-between-CR2032-and-cr2032e
I dunno... I just calls em' as I sees em'
Anthony
Dec 16, 2017 | Taylor Health & Beauty
Remote not working
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
Dec 18, 2015 | Taylor Wireless Digital Thermometer with 1...
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
How do i change the battery for this model. I can't seem to open it, to do so.
The battery is in a little tray that slides out. Use a screwdriver to push outwards on the groove on the back under the battery symbol. You may need to use a small jewelers screwdriver to pry on the sides of the tray, which is the black rectangle on the bottom side of the thermometer.
Aug 07, 2013 | Taylor 1443 Compact Digital Thermometer w/...
Does the outside sensor use batteries?
yes, behind the cover, it takes 4 screws to remove
2 are easy but the other 2 are under the flip up stand
Sep 19, 2012 | Taylor 1525 Wireless IndoorOutdoor...
Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
Jan 14, 2012 | Measuring Tools & Sensors
Need instruction manual
www.taylorusa.com/media/IBs/1524_ib.pdf
Sep 24, 2011 | Taylor 1525 Wireless IndoorOutdoor...
Taylor 1525 Wireless IndoorOutdoor Thermometer With Hygrometer Logo
255 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
