Question about Amana Heating & Cooling
Where is the heat pump located in an amana tpac.
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Setting Amana Heat Pump Thermostat.
The 2H/1C is one stage cooling two heating. Is it s touch screen or not. I mean no buttons. If not go to mode setting. Push mode till you get to heat not emerency heat abd then set temp. Keep in touch. Rus
Nov 19, 2009 | Amana PTH123B25AJ Heat Pump Air...
I have had this amana ac for 10+ years. The only time i feel the cold is when im standing right next to it. Do i need to get a new freon tpac?
i would get it serviced by a contractor that works on amana so you can have your refrigerant levels checked filters replaced and a new belt if it has one
Jul 30, 2009 | Heating & Cooling
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
Service code FP
I know some manufacturer's use the code FP for Freeze Protection.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Dec 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Apr 20, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
27 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
