Question about Bang and Olufsen Beosound 2000 Shelf System
Fixing beosound 2000 door
Door on beo opens and closes but not consistantly or with hesitation
  • albrenda Feb 16, 2009
    Glass door works intermitently. Always opens when closed but does not always close automatically.
  • 122 Answers
Clean/lube door guide rails
Posted on Jan 11, 2010
So I close my car driver side door and it automatically says on the dash board that my door is open?? Any suggestions on what might be wrong. Its a 2011 Ford edge if that helps at all. thanks
Your door ajar system is tied into the door latch mechanism. if the door still appears to close tightly, and the door latch works properly, then you may need to adjust or replace the latch, though ford has listed a cleaning procedure for the latch that involves using a tool to test latch position and manually closing the latch (while door is OPEN) using a screwdriver 10-20x and monitoring to see if the latch consistently shows CLOSED and OPEN when it should.
If pushing the door closed after its already closed causes the lamp to turn off, an adjustment of the latch may help, or cleaning the latch contacts may also help. If the door never shows latched regardless of how hard it is pushed, it may be a defective latch, or a wiring problem (Door wires sometimes break in the door harness between the door and the side of the dashboard when the harness enters the vehicle).
Feb 24, 2015 | Ford Cars & Trucks
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Nov 06, 2014 | Samsung RSG307AABP 30 cu. ft. Side by Side...
My moonroof on my Lexus es300 hesitates when I
the switch you are using is sensitive to finger pressure changes,
Test: while not driving.
try to be consistent with finger pressure on the switch.
Oct 14, 2014 | Cars & Trucks
How do I change Bang & Olufsen Beosound 2000 door belt?
I just did that ; took an 031 oring or was it an 032; and you have to pull the whole drive mech out; it is tricky and if your not small mech inclined don\'t do it; There is a few gears and they work in tandem so when you put it back together it has to be just right; if you take it out take pictures of it as you take it apart because you will never remember how it goes back together; easy to get out; a pain to put back together. And it will all come apart just to put that oring in.
May 31, 2013 | Bang and Olufsen Beosound 2000 Shelf...
2006 Honda Odyssey electric door won't close
there is a slide door control module for each door
Jan 28, 2013 | 2006 Honda Odyssey Touring
Jeep and consistant beeping
there are sensor switches on the doors, open one of them and look at the side of the vehicle where the lock is that holds the door close, you will notice a small rubber push button there ,, when you press it,, it closes in turning off the door lights and letting the car know the door is closed.. One of those one the doors is shorting out, by a broken wire or a stuck sensor,, you need to take them out and check the wires connecting them, or play with them by pushing them in and out rapidly until the beeping stops.
Dec 30, 2012 | 2000 Jeep Grand Cherokee
My glass doors only open partly on the 2500 Beosound system If I take off the glass doors the mechanism opens and shut fine . What can the problem be ??
Hi, I am having the same problem.I am thinking of bringing it to a B&O repair centre but if you found a solution, I am very interested to hear it.
Dec 30, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I have a beosound century and whenever the glass door opens, it makes a ticking sound. I think it is something to do with the cassette dock. Please help.
This mechanism has overload coupling inside. When mechanical overload occurs the coupling may klick. Else doors are jamming so coupling is set too low. Check doors and if they are easy look at coupling - it has spring and screw adlustment at center of linkage drive whell.. I don't know Your model but in Ouverture it is easy to reach. But don't try if you are not experienced (You didn't damage minimum 10 sets in life :).
Jun 13, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Bang & Olufsen Beosound 3000 Ouveture CD Problem....Please Help!
Chances are you will need a replacement cd mech assy to fix this problem assuming you have already cleaned the laser lens(cotton bud with ethyl alcohol or isopropanol).dont know of universal remote for b&o but some specialist remote replacement companies do one for beolink1000 which will operate your product.
Feb 15, 2010 | Bang and Olufsen Beosound 4000 Shelf...
1,084 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
