Question about Kensington Expert Mouse Trackball
Why won't my rollerball work? - Kensington Expert Mouse Trackball
Rollerball not working
A software reload should fix it. If that doesn't work it should just need a cleaning.
May 03, 2011 | RIM BlackBerry Curve 8520 Smartphone
Tip
How to fix a faulty Blackberry rollerball/trackball
There are a few relatively simple solutions to fixing a faulty Blackberry rollerball/trackball.
Compressed Air
Spraying some compressed air on the ball and round the sides of the ball can sometimes loosen the compacted dirt & dust on the rolling mechanism.
You can pick up compressed air from your local hardware store.
WD40
Spray a tiny amount of WD40 on a cotton bud and rub it onto the rollerball. This can free up the mechanism and lubricate it.
Removing and Cleaning the Rollerball/Trackball
  1. Using a small flathead screw driver gently prise the silver ring around the rollerball from the top (be extremely careful as the catches are made of plastic and can break easily)
  2. The rollerball module should come out with easy
  3. Using a clean paint brush, gently brush the inside of the Blackberry where the module came from
  4. Using a toothbrush clean the rollerball module gently around the rollers on the underside and also clean the actual rollerball
  5. When replacing the rollerball module it will only fit one way so don't worry about putting it in upside down
  6. There are three plastic catches on the silver ring, there should be one at the bottom & two at the top. Line them up on the phone and press it back in place gently.
Replacing the rollerball/trackball
Sometimes the mechanism or the rollerball can be come damaged and cleaning will not solve the problem. In this case you can replace the rollerball by following the instructions above about cleaning and purchase a replacement rollerball from eBay or one of the other countless online stores that see Blackberry parts.
I would always recommend that you buy genuine Blackberry replacement parts as these are usually of a higher quality than copies.
on Dec 18, 2009 | Cell Phones
Rollerball will move, but won't click to activate applications. Nor will the buttons work to answer or turn phone on/off? The side buttons won't work either. All other aspects of the phone are...
my friend it is easy just open ur phone and clean ur rollerball u find calceur white.this because ur mobile infected by water .and tel m later
Jan 04, 2010 | RIM Blackberry Curve 8300
Blackberry curve rollerball won"t scroll down
You probably have dust in it. You need to clean it.
Take it to a service center and they will have it cleaned.
Dec 30, 2009 | Cell Phones
Rollerball assembly help
this link tells you how to put it back in the correct way...
http://jsdoodnauth.wordpress.com/2008/09/23/blackberry-pearl-trackball-stopped-working/
very good explanation includes pictures
May 04, 2009 | RIM BlackBerry Pearl 8100
My rollerball won't click.
I'm having the same problem with this. One of my friends and a Att worker have suggested that replacing the Rollerball with a new one which can be bought off Ebay for 5 or 6 bucks can fix the problem. If that does't work then check to see if water damage has taken place, if any moisture has gotten to the phone it may be that. Other then replacing the rollerball i have no other solution.
Apr 17, 2009 | RIM BlackBerry Pearl 8100
had same problem. used rubbing alcohol with a cotton swabb. Took a couple of applications, but worked brilliantly within 10 minutes. Thanks!
Mar 06, 2009 | RIM BlackBerry Pearl 8100
Rollerball of my blackberry8100 is nt working
Use Rubbing Alchohol on a Q-tip to clean the roller. This happens to me all of the time and this always solves the problem
Jan 28, 2009 | RIM BlackBerry Pearl 8100
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
HELP!!!!HELP!!!
Try blackberry.com, they will have links to buy parts, also crackberry.com is great too.
May 05, 2008 | RIM BlackBerry Curve 8310 Smartphone
Kensington Expert Mouse Trackball Logo
22 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
