Remote no longer works with TV.
The remote will not change anything. When you push the button the lights flash on the tv but nothing happens. Won't change channels, shut off tv or anything else. Somehow the tamper proof was turned on and I don't know how to fix this problem.
  • wolde43 Jan 24, 2009
    What kind of tv or tell me what brand ? then i might have the answer.
techman
  • 3130 Answers
SOURCE: tv wont turn on
I looked this set up, and Unfortanatly there is no universal remote that will unlock the set and also theres no way to do it without the original remote. Sorry to be the one with bad news. Also the right remote is available at 1-800-remotes or http://www.remotes.com for about 52 bucks + shipping. Good Luck
Posted on Jul 04, 2006
  • 97 Answers
SOURCE: Tamper proof when you don't have original remote
According to SHARP support documents, the only solution is the original remote. The universal remotes do not carry this feature. It is the same for SONY TV's as well.
Posted on Jun 25, 2007
  • 319 Answers
SOURCE: tamper proof ????
call tech support
Posted on Mar 11, 2008
Agent Dort
  • 216 Answers
SOURCE: Stuck on tamper proof.....remote is lost
Greetings horsepoor2,
Yes, there are a few options for new remotes for this unit. You can find several of them at the "order parts" option found at the bottom of www.bestbuy.com. In fact there is an option to purchase the unit that matched up directly with your television
which is RRMCG1330PESA!
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 13, 2008
palaboy
  • 5807 Answers
SOURCE: Tamper Proof red LED is
To edit set up , color etc, ....., should be done , once your
TV is in Normal Mode . ( I will post it later ).
To have a Normal Mode , you need to check and open your unit
if it is possible for you to DIY, let me know so I can post
more details to help you troubleshoot.
Voltages will be measured , but possibly nothing to extract
yet.
Posted on Aug 17, 2010
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
Electro Med Services...
