Question about Bias iProRecorder Premier Voice & Music Recorder
Trouble downloading a recording from ipro recorder
I have used this program for months and it's worked fine. I recorded a meeting the other night, and am trying to download it, and it goes through all the proper steps but then it just hangs there in the download - ack!
It says no info on the programs I want to record and won't record them. The guide also shows no info in those areas.
Janette578,
Make sure the receiver is powered off each night so it can receive updates through the satellite to the guide.
You can force a guide download by unplugging the receiver for 10 seconds and plugging it back in. If that doesn't work, you can run a check switch test from Menu > System Setup > Installation > Point Dish > Check Switch > Test. Let it finish, then exit out of the menu and let it acquire signal and download the guide.
If you have any other questions, or need further assistance, let me know!
Tommy Faust
DISH Social Media Representative
Oct 22, 2012 | DISH Network ViP622 DVR DTV Receiver /...
I have Toshiba Satellite proA200- EZ2204X lapotp. I have installed skype and Action VoIP on my laptop. But the far end people are not able to hear me weather I use inbuilt or External Microphone. Plz
You have to make sure there are drivers installed for the microphone device you want to use. You can check that in Control Panel, Sound, Recording tab. If you have a microphone installed all the settings you can set for it will be there.
Also, make sure that whatever program you are using is set to use the recording device you want. This is normally set to 'system default', but can also be accompanied by a drop-down list of all recording devices on the system.
You can test all installed recording devices from the Control Panel, Sound, Recording tab to ensure that they do work correctly. If they do work there, but not in the program you are using, then the problem is in the program settings.
Jul 04, 2012 | Computers & Internet
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Was given an Ampex AG-440 tape deck that stopped recording after sitting for about six months. Any ideas? (I lost the Manual) Everything else works fine. When put into record mode all lights are lit...
try cleaning the record head, Most people only clean the play back heads on tape players, the record head is just off to one side of the main playback heads , you can use a Qtip and rubbing alcohol to do the cleaning
May 21, 2011 | Audio Players & Recorders
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Sep 13, 2008 | LG Televison & Video
Failure to record on -R DVDs
DVD-Rs do work with the RDR-VX500 ...... I had not recorded on mine for a few months after I ran out of the last batch ....... then I tried recording on the newer Sony DVD-Rs I had ...... would not record on DVD-R ..... turns out the instructions say the recorder will not work with any DVDs faster than 8x .... It looks like it's recording but it doesn't ..... then I noticed the newer DVDs were 16x ...... found an old 8x and tried it and it works fine ..... turns out the unit won't record slower on a 16x, it just won't record at all ...... get 8x and you'll be ok
Apr 23, 2008 | Sony RDR-VX500 DVD Recorder/VCR
Panasonic AG-1980
I have a ag 1960 deck in new condition(I bought it new has about 10 hours on recorder). I have not use it for a year. everything works execpt it will not record vido or audio, the counter will not work. It was never droped?
Rich
Jan 15, 2008 | Panasonic AG-1980 S-VHS VCR
No program information on my sony HDX 560
I had this problem. I found that when you record from the EPG it can change quite frequently. When this happenes then your recording will automatically get deleted. To sort this out I would use the Guide plus system on your box and then the problem wont occur any more
Dec 29, 2007 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Bias iProRecorder Premier Voice & Music Recorder Logo
64 people viewed this question
Top Bias Apps Experts
Erin Wood
Erin Wood
Are you a Bias App Expert? Answer questions, earn points and help others
