Replacing Lennox Thermostat with Lux TX9000TS electronic t-stat
Old t-stat had :
W1, W2, X (these 3 were from same ''wire''), G, Rc, Rh (the two R's were wired together) and Y1
New Lux thermostat has available slots for:
W, Y, G, B, O, Rc, Rh, C
I have wired it using several ideas and tips found, but still have not had any luck with the system working....
one main concern is what to do with the X, and then the 2 W's...do they go together or??
  • 3 more comments
  • Daniel Sorrels Jan 24, 2009
    I am dealing with 6 wires and no heat pump...
    To clarify: The W2 and X, come from the same strand...
    W1, G, (Rc & Rh = 1 wire) (the R's were jumped together) and Y1 all come from a different strand.
    it is a two speed fan but I don't think this matters in this case...
    there is one red wire that jumped to both Rc and Rh on the old t-stat, if I didn't make sense...
    It is a two SPEED fan, not sure what you mean by two stage...
    the colors are:
    white (two of these - the W's)
    blue (two of these - one X, one G)
    yellow
    red
    So I currently have it wired as such:
    W1 to W
    Y to Y
    Red to Rc
    G (which is blue) to G
    W2 and X are not in use...still waiting for system to cycle...
  • Ken Bledsoe May 11, 2010
    So you have 6 wires normal colors are
    red
    green
    white
    blue
    yellow
    brown
    are these the colors you have?
    Do you have just a a/c and gas heat or do you have heat pump? Also how many wires do you have sounds like by your post you have only 4 wires?
  • 334 Answers
Unless you have a 2 stage heat system, all you wire up is W1
X is typically only used for humidifiers, dehumidifiers, air cleaners adn other such accesories. If you have none of these, X is unused.
It is typical to find that the original installer wired black or brown to X at the T-stat and left it unhooked at the unit. In such case, just leave X unused.
If your wires are
Red
white
yellow
green
blue
And if your system is a typical furnace with airconditioner then wire it liek this,
Red to Rc
Yellow to Y
green to G
White to W1
Blue to C (common)
Your installers manual will let you know if you shouild leave the jumper between the Rc and Rh terminals.
O terminal is only used for heat pumps and getas the orange wire.
If your T-stast has batteries and does not require an external power source, then you do not have to have the blue wire to C terminal.
If for some odd reason the maqnual does not inform you obout the jumper to RC/RH Try it firt without the jumper. Run it through all cycles. If all modes do not operate, install the jumper.
Posted on Jan 24, 2009
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
SWITCHING A DUO THERM THERMOSTAT TO A WHITE RODGERS 300 HEATING AND COOLING THE NEW ONE WE HAVE Y,W,B,RH,O,RC,G,A. TERMINALS OLD ONE HS, 7.5,COOL,FUR,HI FAN,FAN, GND,
FUR - OLD T'STAT - (W) NEW T'STAT
COOL- OLD T'STAT - (Y) NEW T'STAT
HI FAN - OLD T'STAT - (G) NEW T'STAT
7.5 - OLD T'STAT - (RC) ON NEW JUMPER WIRE - (RH)
need full model number of w/r thermostat for other wires
Jul 02, 2011 | Heating & Cooling
Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Jul 27, 2009 | Heating & Cooling
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Dec 15, 2008 | Honeywell Electronic Programmable...
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Wiring a thermostat
your red wire will go to the R, RC, or RH terminal on the stat does'nt matter which one ,this is the wire that provides 24 volt from the furnace. the white wire will connect to the W terminal on the stat. If there is a jumper wire that came on the stat going from RC to RH leave it on.
Mar 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,253 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
