Question about Cuisinart Coffeemakers
Dcc 2000 leaks
Our dcc 2000 often has a puddle under it. i think water is gettingdown into the heating element area during filling the tank. there is a drain hole in there and the water is draining thru it and over flowing the grilled catch basin at the bottom. i guess spilling less water in there will fix it.kind of a bad design in that when filling the tank it is very easy to spill into the heat element area. a bigger filler area would help.
March 16, 2009
I bought one of these last week. Boy, was I PO'd when it leaked cold water all over the countertop! I almost took it back to the store- then thought better of it and putzed around with it for a while until I stopped the leak and managed a pretty decent cup of coffee.
Here's what I did- TRY IT AT YOUR OWN RISK!
Once again, you're doing this at your own risk- I'm not connected with any coffeemaker manufacturer or seller- and I don't have any money- so suing me would be futile.....
The object of this exercise is to heat up whatever needs to be heated up in order to turn off Noah's Flood before it hits your counter top.
(1) Clean the coffeemaker thoroughly with cold water. Don't bother drying it.
(2) In a container, put in enough water to make the number of cups of coffee you want. Add a little extra- about 1/2 inch in the bottom of a coffee cup is enough. DON'T POUR IT INTO THE COFFEEMAKER YET.
(3) I used a paper filter- but I guess you can use the goldtone filter basket supplied with the
coffeemaker. DONT USE BOTH- use one or the other! Whichever you choose, put in enough ground coffee for the number of cups you want to wind up with.
Be sure 1, 2, and 3 above are done completely. From here on, you are activating the heating element in your coffee maker, however briefly, with NO LIQUID IN THE MACHINE TO PREVENT THE HEATING ELEMENT FROM OVER-HEATING AND BURNING UP YOUR COFFEEMAKER. And, you gotta be ready because everything gets done QUICKLY after this.
(4) Take a deep breath. Turn the left-hand rotary switch to BREW. The heating element is now powered up. Immediately, pour the small amount of water in Step 2 above S-L-O-W-L-Y into the trough located along the side of the water reservoir ahead of the filter holder. I SAID S-L-O-W-L-Y ! ! !
(5) Select the 2-4 cup button if that's what you want.
(6) Now, pour the rest of the water you have measured S-L-O-W-L-Y into the same trough you used earlier in Step 2.
(7) Check beneath the dispensing lever to be sure there's no coffee leaking. If there is, press UP on the lever and try to turn it off.
(8) Eventually it will quit gurgling and belching. And, your countertop should be dry (If your machine has the same quirks mine did.....)
You really shouldn't have to do all this, not for a $100+ coffeemaker- But, once you get a load of coffee in it, and your counter top is dry, it's really such a convenient way of dispensing a really good cuppa coffee, I think I'll probably keep it and and put up with the hassle.
Maybe this'll jog the engineers into fixing the problem once and for all . . . . .
Posted on Mar 17, 2009
  • far west Oct 02, 2010
    This solution is a bit over the top. I have found that with the Cuisinart design, there are two primary reasons for water to end up on your counter top. 1. When pouring water in, you missed the reservoir. 2. When putting grounds into filter, if they end up outside the filter, they will drop down into the lid of the thermos carafe. If enough grounds get stuck in there, they prevent coffee from getting into the pot and you have a brewed coffee overflow. So make sure you wash out the lid so it's unobstructed and that the filter cone is free of loose grounds.
Gasolne smell around the car
Do not start car. Check fuel line at rear and gas fill tube. There is a high pressure gas line which can rust out. Your gas tank can be leaking.
Have someone use a flashlight, not a lightbulb fixture, to inspect the area for leaks. Lightbulbs produce heat and can shatter and spark to ignite the fuel.
Jan 21, 2014 | 2003 Lincoln Town Car
My refrigerator leaking water its filling up the water
the water pan is a catch for the defroster.When the defrost timer cycles it heats an element in the freezer that thaws ice bulid up and a drain hose deposits the water in the pan.
Dec 23, 2009 | Whirlpool Refrigerators
Water is leaking out the bottom
You MUST return this product or throw it away! This is a problem seen often and the biggest risk is electricution. The hold tank for the fresh water is leaking and it is leaking water into the area housing the heating element for the caraf as well as the pump and a few other nasties.
This is a very serious problem. Do not try to fix it. A new unit is much better than either getting shocked or burning your place down.
Dec 04, 2009 | Cuisinart DCC-1200 Coffee Maker
My cuisinart DCC-2000 leaks all over the counter when i make coffee, anyone had a similar problem? i hear rumors that there is tubes inside that can go bad....
Be sure to not overfill the reservoir. Look at the back where the lid hinge is and you will see that the opening is lower then what the tank looks like it can be filled to. Had the same problem and stopped it by being a little more careful when I filled it.
Apr 14, 2009 | Cuisinart DCC-2000
Leaks water out overnight
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
Mar 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Leaking water in bottom of freezer
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 06, 2009 | Kenmore Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Cuisinart DCC-2000 leak
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Jun 29, 2008 | Cuisinart DCC-2000
Quisnart DCC-2000 12 cup (leakage)
If the DCC-2000m is filled past the 12-cup mark, there is a spill gauge at the back that will allow the coffeemaker to keep the cup count exactly at 12 cups.
Dec 11, 2007 | Cuisinart DCC-2000
Cuisinart Coffeemakers Logo
152 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
