Question about Hotpoint WD62 Front Load Washer / Dryer
Keeps fusing my washer keeps fusinfg during a cycle if i change the fuse it works again then stops after a while any one know why thanks
  • 67 Answers
Yes the heater could cause this but so could the motor,or dryer heater, but because any electrical component couldcause this unless you have a Insulation Resistence Tester it will all be guess work if you are not electrically minded I would leave it to an expert. THIS FAULT IS A SHOCK HAZZARD.
Posted on Jul 12, 2007
Probably the heating element it sometimes absorbs water, tracks down to earth and blows the fuse
Posted on Jul 11, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My zanussi ZWD12270G1 wont turn on
THE MOTHERBOARD MIGHT HAVE FUSED OUT , NORMALLY YOU HAVE TO TAKE THE TOP OFF AND LOOK FOR A FUSE NORMALLY A 4amp LOOKS LIKE A GLASS FUSE LET ME KNOW
Dec 29, 2013 | Zanussi ZWD1270 Front Load Washer / Dryer
Whirlpool duet washer power went of during a cycle
If the power is not reaching the m/c., switch off plug outlet remove the plug.
( safety measure ).
Now open the machine and check the fuse. If you trace the power cord you will reach the fuse area.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Maytag stopped working,
I'm not sure if there is a fuse inside, but if you found the diagram, you can trace the power.
on a dead set, the most common problem would be the timer switch. the one that you pull and push.
check the contacts of the timer switch.
tnx again,
drcool
Oct 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Keeps fusing
It seems like something is prevent tub's free movment. Try to spin the clothes tub by hand and look for a free movment. In case it doesn't move smoothly,maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent its clear spin. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Be aware you should disconnected the power cable before starting your tests !! Good luck !!!
May 23, 2006 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
