Diahatsu copen leaking boot
We have siliconed brake light. Still lots of condensation and pools of water
mgprice
  • 744 Answers
SOURCE: lots of water pooling on top shelf
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike
Posted on Jul 23, 2009
morse008
  • 1111 Answers
SOURCE: Au Series II ford Forte, boot leaks
remove the spare tire and inspect for rust or holes to allow water to enter it ...or have a person sit inside the trunk area and use a hose starting low and going up slowly to trace the source of the leak
Posted on Aug 25, 2009
jmgldsmth
  • 2005 Answers
SOURCE: water is pooling in the fridge from the icemaker,
behind the freezer wall is a drain to the bottom condensate tray under the refrigerator this is clogged remove the plastic inner wall remove the ice buildup on the coils and, coil shelf then: clear the drain with hot water poured into the drain hose with a funnel
Posted on Sep 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: My intex pool filter is constantly leaking and we
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
twoduckster
  • 370 Answers
SOURCE: 1997 diahatsu charade ltd overheating
open the car hood. look at the radiator, and then the top radiator hose. follow that hose to the engine. the hose connects to the thermostat housing cap. under that cap is the thermostat. here's what you need: ratchet, and sockets, flat-tip screwdriver, scraper, pliers, a new thermostat (any auto parts store), a new gasket, and some gasket sealant. Question, how old are hoses? if 3 years or old, let change those also. 2 new hose, 4 hose clamps, and some coolant. If we're changing hoses with this, lets start. drain the radiator, and remove the hard hose first, the bottom. now remove the top.hose, and lets start the thermostat. remove the bolts holding down the cap, and gently pry off the cap. flip the cap over, and scrape it clean to metal(we want NO leaks). now reach down and remove the thermostat, and lets scrape the housing clean to metal. place the new thermostat in the housing, and lets put a thin coat of gasket sealant on the housing. place the gasket on the sealant, and pick up the cap. apply a little gasket to the cap. place on top of the gasket, and bolt it down. now hook the hoses(if your changing them)and let sit 30 minutes for the gasket sealant set. after that, let add the coolant, and water. start the car, let it warm up. when the new thermostat opens, add more coolant as need to top it off. Hope this helps
Posted on Jan 03, 2011
Water leaking into boot
Look at the seal closely. If you see where it comes threw. I cut there with a razor blade and fill the inside with cotton. Then silicone the cut. Let it set an hour before closing the boot. If you have a brake light mounted in the boot. This is usually where a lot of water will come in. I silicone them in also. Spoiler on the boot, I remove them and silicone them down.
Jul 27, 2016 | Hyundai Excel Cars & Trucks
Water on back seat floor, left and right
Is it AC condensate or is it antifreeze?
Nov 08, 2015 | Seat Cars & Trucks
Water getting inside my boot lid. No idea how ? pours out when opened also leaked into spare wheel well. Causing damp inside boot and going mouldy. HELP
what model estate or saloon. estate check the electrics at the roof point. saloon check the rubber seal also if the vents get blocked in the boot you get a build up of condensation in the boot and the boot pannels inside.
Jan 19, 2014 | 2000 Audi A4
Condensation In Trunk 2001 Buick LeSabre
Is it possible the trunk lid is not aligned right and not applying pressure to the gasket ? Or do you have a crack in the seam where the quarter panel and the center pillar meet up ? Or is it getting in behind the tail lamp ?
Jul 15, 2013 | Cars & Trucks
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
Water flows out the condensation tube even when the heater is not runiing causing the pool to leak down. The heater is 4 years old. Thank you.
It sounds like there is a leak in your system. The condensation tube is to drain off the water because one of the byproduct of combustion is water and it condenses on the heat exchanger. Since it is only 4 years old it might be under warrantee for this issue. The problem might be simple but could be very expensive if the heat exchanger has a leak.
Aug 06, 2011 | Jandy Laars Hi - E2 350,000 Btu Heater
My daughter's 94 Acura Integra RS hatchback has a water leak problem. Water is coming in from somewhere and pooling in the spare wheel well, up to a inch or so deep. A friend said to check the tail...
easy to check ,take hose and spray water around lights then check inside if leaking, remove and seal with silicone reinstall. Once silicone has dried test with water hose. It could also be the rubber seal around the rear hatch can also be checked with water hose if leaking replace weather strip
Aug 20, 2010 | 1994 Acura Integra
LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
May 18, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
2004 4x4 colorado water leaking in threw the cab brake light
take the light cover off get some clear silicone put in around the wires and a small amount around the light cover its self
Oct 04, 2009 | 2004 Chevrolet Colorado
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
