Question about Thermador CM302U Electric Double Oven
Thermador F61 fault code - Thermador CM302U Electric Double Oven
Kenmore wall oven fault code f61 what does it mean when it says this fault code
Find the model number. See which oem manufacturer built it using the information at
Sears Kenmore Fault Codes AppliancePartsPros com
and then look up the code under that manufacturer.
Feb 17, 2017 | Kenmore Ovens
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
Fault code e115
pin service bulletin for codes added!
check the main pc1 contactor and wires controlling it!
: detected open when commanded closed.
May 06, 2014 | Thermador Ovens
Thermador CM302 shuts off intermittently. No error code, timer remains working.
Dear Craig Buck,
This is either a fault with the timer, or you have a fault with the thermostat. Get a multimeter onto that thermostat and test it, after removing the heating element of course. Then get back in touch with me and I will give you the fix.
Yours sincerely
Ouszen
Feb 07, 2012 | Thermador Ovens
On self clean mode with thermador single oven showing f52
F52 means your upper oven door latch is acting up.
This means that the upper oven door is not in the correct position; check it or replace the upper oven door latch assembly for fixed.
I hope helps.
Jun 23, 2011 | Thermador Ovens
THERMADOR MODEL SEC302BP installed in 2006. I am getting a infrequent error code of F-64. This double oven has already been recalled due to the self cleaning mode starting a fire. do I need to pay a...
You may have to pay a service technician out to fix this issue, if the update insulation kit was already added this could be causing the issue depending on if it was installed correctly.
This error code has to do with the air flow the fan is could have failed as well, the hall sensor that is built into the fan motor will often fail creating this issue.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Thermador SEC302 Electric Double Oven
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
Thermador double oven SC302 Fault code F34
first check to see if the oven is under warranty it might also be a manufacturers defect
Dec 30, 2007 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador CM302U Electric Double Oven Questions
Thermador CM302U Electric Double Oven Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
