Question about Gateway GT5220 PC Desktop
Need replacement mobo for Gateway C51PVGM-GB
Does anyone know of a replacement motherboard for my Gateway GT5220? The motherboard part # is C51PVGM-GB
Thanks!
  • 2 more comments
  • southparkadd Jan 24, 2009
    I agree, but I want to find basically a compatible board (same RAM type, etc), so I don't have to upgrade anything but the board. I found an exact rpl, but it's $179, and I know there has got to be a cheaper board out there that has the same specs. I just want to make sure I get a board that's going to basically be as close a match as possible
    Additionally, I've replaced the CPU with the same one that it came with (Athlon 64x2) so I need a board that is pretty much the same
    Thanks. I found an exact replacement for this board, but was trying to find a cheaper board that had all the same features.
  • Roberta Smith
    Roberta Smith May 11, 2010
    As it is a desktop computer ... it doesn't have to be the exact motherboard... this might be a good time to upgrade the cpu and motherboard
    Robert
I have the motherboard that you need. i am upgrading my system and i guess wont need it anymore...
Posted on Jun 12, 2009
    Brigadier General:
  • 5,158 Answers
Find the specs on the board you have and do some shopping around and research.... lots of boards are compatable with that cpu (just make sure the board has the right socket). www.tigerdirect.com and www.newegg.com and pretty good places to look.
Robert
Oh and please take a moment to rate this solution thanks
Posted on Jan 24, 2009
    President:
  • 2,692 Answers
Motherboard drivers
This appears to an EliteGroup Computers (ECS) rather than Gigabyte motherboard. It is fitted to some Gateway computers and the following links should enable you to download the relevant drivers for installation when you choose your OS
http://driverscollection.com/?H=C51PVGM-M%20(V1.0)&By=ECS%20(Elitegroup)
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=695&CategoryID=1&DetailName=Feature&MenuID=21&LanID=0#fragment-Download
Dec 24, 2013 | Gigabyte Computers & Internet
Motherboard
Is there any fan noise or beep codes or any sign its powering up>
check to see if the powersupply comes on with fan..then chk for processor fan and video next.
most gateway have OEM power connection that is not compatible with other supplys
chadman
Dec 24, 2013 | Computers & Internet
Compatible Gateway Motherboard
BIOSTAR MCP6P M2+ 6.X AM3/AM2+/AM2 NVIDIA GeForce 6150 / nForce 430 Micro ATX AMD Motherboard
Jun 09, 2013 | Gateway GT5220 PC Desktop
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
How do i get a c51pvgm gb motherboard to recognize a new sata hard drive.
Better get a SATA adapter card, as this mobo uses IDE (PATA) harddrives. http://www.legendmicro.com/store/4761_ECS-C51PVGM-GB--Gateway-4006136R-SK-AM2-2000FSB-DDR2-MBTX-AVL---New-C51PVGMGB.lmsp
Aug 24, 2010 | Gateway GT5220 PC Desktop
I have a mobo C51PVGM-GB that I would like to upgrade the video card and not use the one built into the Mobo.
You are upgrading the graphics.
Instead of using Integrated Graphics, you will be using a dedicated graphics card.
Integrated Graphics is also referred to as OnBoard Graphics.
On the motherBoard.
The GPU (Graphics Processing Unit) is soldered to the motherboard.
It is not a video (Graphics) card.
A dedicated graphics adapter card has it's own GPU, and graphics ram memory.
http://en.wikipedia.org/wiki/GPU
Information on the Gateway 4006136R - Nvidia GeForce 6150 AM2 uBTX 1394 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
Viewing this small photo of the motherboard, the Orange long slot you see is a PCI Express x16 slot.
1) The Northbridge chip is a C51PVG
2) The Southbridge chip is an MCP51
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply Processor for short)
3) Made by ECS
4) Has an AM2 processor socket on the motherboard, for AMD processors.
Continued in an additional Comment.
Jun 12, 2010 | Gateway GT5220 PC Desktop
My GT5220 is less than two years old and the motherboard failed according to Gateway. All I want to know is what sort or mother board ie. model # etc. I should look for to replace it. Gateway quoted...
If you have the original Mobo in hand and feel a little curious about how at only two years old it doesn't work anymore, consider this. Inspect the large electrolytic capacitors on the board. (those round cylindrical things that stand up) for swelling. The tops should be perfectly flat. If they show swelling (domed) they have failed, and replacing them will likely bring it back. It takes good soldering skills and at least a 60-watt (100-watt preferred for this job because of the amount of heat required) temperature-regulated soldering iron, and the replacement parts. The bonus to this is you will not need to re-install your windows system. You might even feel a little like you have beat the system.
May 15, 2009 | Gateway GT5220 PC Desktop
Gateway GT5220 PC Desktop Logo
2,661 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
