Question about Amana Refrigerators
My amana side by side ars2662bs freezer working fridge is warm
This is third time after a couple of days it works fine for about 45 days and does it again
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 56 Answers
SOURCE: Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Posted on Dec 05, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
My may tag fridge GS2126PADB seems to run fine but the freezer is not blowing cold air and fridge & freezer are warm.
There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
Jun 27, 2014 | Amana ARS266ZBS Side by Side Refrigerator
Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer side blowing all the time and fridge side is warm with no cooling on amana side by side unpluged and defosted with hair dryer and it worked for a couple days then went back warm in fridge side...
You have a defrost issue.
Adaptive defrost control.
Defrost thermostat.
Defrost heater.
These are the only 3 parts involved.
If there was a model number I could be more help.
Feb 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
either compressor is jammed or the starting relay with capacity is faculty
Jan 13, 2009 | Amana ARB8057CSL Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Nov 04, 2008 | Amana ABB1927DE Bottom Freezer...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
