Question about Kenwood BOX woofer with built-in amplifier KSC-SW160
Ksc sw 160 - Kenwood BOX woofer with built-in amplifier KSC-SW160
Kenwood KSC-37 why does red light blink
In the manual, it states that if the LED is Blinking Red "The battery pack is defective or the battery pack contacts
are not properly mated with those of the charger" Below is a link to the manual.
http://www.buytwowayradios.com/products/resources/Kenwood/KSC-37-Owners-Manual-1.pdf
Apr 04, 2013 | Kenwood KSC-37 Replacement Charger for...
How do i hook up my ksc-wa100to my stock stereo
if you are looking to just run the power solely through other speakers this will prolly not work you will still need to have power going to the amplifier.
Jan 05, 2013 | Kenwood KSC-WA100 Car Subwoofer
How to disconnect Kenwood KSC-WD250 Powered Subwoofer from my car stereo
There should be RCA's power and ground connections. the rca's run behind the stero, the ground runs somewhere to the frame of the car and power runs to the positive post on the battery.
Jun 11, 2010 | Kenwood KSC-WD250 Car Subwoofer
Kenwood KSC-SW10
make sure it has a good ground
Dec 04, 2009 | Kenwood KSC-SW10 Car Component System
Ksc-w800 installation
Any sub will need an external amp - a head unit amp doesn't have the suds to drive it. You can try it with the deck but you'll only get a whisper out of it.
Sep 01, 2008 | Kenwood KSC-W800 Car Speaker
Ksc-wa100
Sep 01, 2007 | Kenwood KSC-WA100 Car Subwoofer
Kenwood KSC-WA801
if you don't mind a large car battery (and battery charger) in your living room, it will work. Another option is to get a 12 VDC power supply, capable of sourcing 100 or more amps, but that would be too costly.
Jun 15, 2007 | Kenwood SW-38HT Subwoofer
Installing
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 28, 2006 | Kenwood KSC-WA82RC Car Subwoofer
Kenwood BOX woofer with built-in amplifier KSC-SW160 Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
