Question about Dell 5100cn Laser Printer
Can't unlock the black toner cartridge on my dell 5100cn
Corysf62
  • 188 Answers
SOURCE: Dell 5100cn printer
The only effect that the "non Dell toner" setting has is to raise the fuser temperature to the maximum. Since all toners are made up of ink and plastic, the fuser is what melts the fine plastic to the paper.
Dell toner is designed to melt at a lower temperature, however, since the non dell toners temperature value is unknow, this setting allows for that unknown.
In any case, neither of these things will cause lite, or faded print. In Fact, the toner cartridge for this model is actually nothing more then a toner storage device. Some cartridges contain the toner, the developer, and the drum. On the 5100 and the 5110 this is not the case.
The photo developers are located behind the imaging drum. you can see the 4 seperate developers, in the developer frame, when you remove the drum unit.
More then likely, if only the black is printing poorly, and the colors are printing ok, then the black photo developer is defective. This is a very messy job if you do not know what you are doing, and very involved.
You need to remove the top cover, the left side cover, the high voltage power supply, the supply tubes ( where the toner travels from the actual toner cartridges down to the developers ). Then once the tubes are removed, you have to remove the developer frame from the printer. Then you can get to the actual photo developer.
Good luck.
Posted on Oct 01, 2008
Corysf62
  • 188 Answers
SOURCE: Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Posted on Oct 30, 2008
kakee
  • 1268 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
wrinaldo
  • 185 Answers
SOURCE: I AM CHANGING THE BLACK TONER CARTRIDGE ON A DELL
Either the "toner cartridge sensor" N4445 isn't reading the chip in the toner,
or an MCU board P5281 or EEPROM is defective
-Whit :)
Posted on Jul 31, 2009
  • 159 Answers
SOURCE: Recently changed the black toner cartridge in the
Replacing the toner cartridge should fix the problem.
Posted on Mar 12, 2010
5100cn Printer printing cyan
This most likely to be a leaking toner cartridge in this particular printer. I would recommend changing the toner cartridge.
Jan 23, 2013 | Dell 5100cn Laser Printer
I'm working on a Dell 5100cn printer. it came in with a yellow developer issue leaking toner. I replaced the yellow developer and cleaned the unit. In the process some of the developers were emptied to...
you have to do is remove all 4 hoses, the single electrical connector at the top of the frame, and then the frame will pull lose from the printer. If you do remove the developer frame, make sure you clean the ROS glass, this is actually the printhead, located behind the frame when removed and as well as other parts. Reopen the black cartridge, set it well and lock it completely. There is a cheap under the toner, make sure that it is not corrupted, if it is, then you should remove it out and replace it with old toner cartridge. If the problem still exists then you can check this web link :
http://support.dell.com/support/edocs/systems/5100cn/en/ug/section20.html.
Apr 08, 2011 | Dell 5100cn Laser Printer
Trying to replace black toner, using a generic cartridge OMO2904 cannot get to fit
please do not damage the printer, if you have the user guide you will find a list of recommended toners for the unit otherwise see below:
http://www.retrevo.com/support/Dell-5100cn-Printers-manual/id/261ag606/t/2/
Please do send your vote if this resolves the issue,
regards
Mar 24, 2010 | Dell 5100cn Laser Printer
Dell Laser 5100
Means the Yellow Toner Cartridge is not communicating with the printer. If you've installed a third party yellow toner cartridge, go to the Dell Printer Configuration Web Tool to set the toner to non-Dell toner. If it is a Dell cartridge, the procedure is to turn the printer off, wait 10 seconds, and turn the printer back on.
Feb 24, 2010 | Dell 5100cn Laser Printer
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Dell 5100cn printer
Good luck.
Aug 22, 2008 | Dell 5100cn Laser Printer
Dell 5100cn code 009-363
Nicholas -
There is no real solution to this problem that I've been able to find. And I myself have not been able to find anyone that has the service manual for this color printer.
Here is what happened with my printer. I normally use this one company for compatible toner cartridges for our office printers. I've never had any issues with their HP, Brother, Canon Phaser or Dell laser products - EVER. When I went to re-order my Dell 5100cn toners again from them - ordered 2 black and 1 each cyan, magenta and color - none of the toners worked right. When they were installed, the machine produced that 009-363 restart printer message.
Now this company has ALWAYS taken care of me. We thought maybe the chips in the toners were outdated or something compared the the recent firmware update my printer had recently had. So they shipped out a complete new order for me. But the second set of toners did the same thing. So they sent one of their Dell Certified technicians to the office - we are on a cleaning plan with them so he just looked at the Dell printer while he was there doing the other work. He could not find anything physically wrong with the first or second set of toners, but yet they would not work in my printer. He even tried going through the menu options to select "allow non-Dell toners" too - thinking that maybe the printer just wasn't liking the Dell compatibles. I never had to do this before with their Dell compatibles, but it was worth a try. But even when selecting that, the printer still produced the 009-363 restart printer message. He took the toners back with him, and left me with a set of Genuine Dell toners - just to get me through what was happening so I wasn't down a printer.
The company called me and said when the technician returned with the compatible Dell toners they'd shipped me, they installed them in their test Dell 5100cn printer and they worked fine! So it was appearing that the problem might have been my machine or something.
I searched online everywhere, and the supply company I used also spoke with Dell tech support on my behalf - but got no where with Dell as usual - their Tech Support is totally useless!
About a month goes by, and my supply company says that they received a new shipment of Dell chips that have a newer firmware than even what my printer has, and that they'd like to send their technician out again to test them out in our machine. The tech came by, installed all of the toners - and they worked!
So it definitely was something to do with the firmware that was on my printer versus the firmware that was on the chips in their toners. My printer for some reason did not like that "lot" of toners they had made using those chips. And when they produced their next lot with the new firmware chips, the printer accepted everything ok.
Since then I've used their Dell compatibles with no issues. I think it was just a fluky thing as it hasn't happened since. Overall I think you just need to find a company like mine that continuously produces new toner cartridges using new Dell chips in their toners. Once in a while you might get a fluky one like we did, but my company definitely took care of us. Just try to find a company that has a good cartridge - you don't have to keep buying the expensive Dell brand - especially when they don't even know what the problem is caused by either.
Jul 01, 2008 | Dell 5100cn Laser Printer
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
