Question about IBM ThinkPad R40 Notebook
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list there is no wlan! just the lan appears. HEEEELP!!
  • rudi231 Jan 27, 2009
    Thanks and sorry for the delay.
    Did it, but Start is not available. Only Stop and Restart.
    Pressed Stop (Start appeared) and then Start. No news. Situation the same: no wireless icon in the Notification bar, no light in the radio notification LED, no wireless adapter under the Network Adapters (only the LAN is there).
    By the way, unscrewed the cover on the bottom of the computer and verified that the wireless card is there, connected (Intel something).
    Thanks again. Any other ideas?
  • vicky_594 Feb 18, 2009
    not to install ethernet convertor
  • 520 Answers
If drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Posted on Jan 24, 2009
  • tat4u
    tat4u Jan 27, 2009
    I suspect you have no wireless manager so use windows manager...
    go into control panel and double click administrative tools ..next doule click services and scroll down to wireless zero configuration (double click it)and select start you will now be able to
    view / select available networks
    Problem Solver:
  • 21 Answers
Go to www.lenovo.com and download ThinkVantage system update, Its a Program that installs all your laptop drivers and scans for the missing software and drivers. You will need Microsoft NETFRAME Work 2.0 installed for it to work. I have it on all my IBM ThinkPad laptops and it should work. After you install it go under START, Programs, ThinkVantage, System Update. and follow instructions. If it still doesn't detect it, your WiFi card maybe disconnected or bad. All IBM ThinkPad R40's come with a WiFi card built in.
Posted on Feb 24, 2009
I need r40 laptop mother board driver
Posted on Feb 21, 2009
3 Suggested Answers
tat4u
  • 520 Answers
SOURCE: Lost wireless - Ibm thinkpad r40
haha worrying isnt it...
after reinstallation of windows no drivers for blutooth , wireless quite often modem and same vga,
windows by default does not install because need specific software ...(drivers)
what you need to do is first of all find out what wifi it is ; like wlan400 e.g.
you then need to download and install the driver for it .as soon as the driver is present windows will detect and install device,
look in device manager for devices with no drivers intalled.
same precedure for each device.
Geekman
  • 32281 Answers
SOURCE: thinkpad r40 - wireless disappeared
Go to the control panel, then System, then Hardware tab, then Device Manager. Then Network adapters - you should have two network adapters one LAN and one wireless.
If most likely have one, the LAN adapter and a yellow ? against a network adapter - this will be a wireless adapter (its not installed)
Check your BIOS and make sure the wireless card is enabled.
You need to download from the IBM/Lenove WEB site the wireless driver (there may be several types that is installed for your model laptop). Make sure you select the correct Windows version driver.
When you run the driver,it will uncompress and copy to your hard drive in C:\drivers. You can then install the driver from this directory. If it doesn't work then repeat with another driver, most likely one that works will be the Intel one.
Posted on Jan 25, 2009
How can i turn on wireless adapter on the IBM thinkpad R40 laptop.I can't see the wireless adapter switch.......the drivers are already installed successfully.Please HELP!!!!!!!!!!!
the r40 has no hardware switch. it has a software switch. you must first determine what type of wifi card if any is installed. most of the stock cards are intel or cisco and the ibm support site has the software used to control them. sometimes, thru the network connections, windows can take control if the drivers are installed
Sep 27, 2010 | IBM ThinkPad R40 Notebook
I cant get a wireless connection on my IBM R40 using a Linksys G
I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
I have a IBM thinkpad R40, i upgrade to xp professional from windows 2000, i have a problem with the LAN which always display no connectivity, i have installed the LAN driver downloaded to the IBM website,...
http://www-307.ibm.com/pc/support/site.wss/MIGR-54046.html
start here,determine witch of the two options you have in yours,intel pro 100 VE network connection or intel pro 1000 lan adapter then download and install according to instructions good luck,aloha from maui todd0708
Oct 22, 2009 | IBM ThinkPad R40 2681
IBM R40 SoundMAX Dirver not found error
http://www-307.ibm.com/pc/support/site.wss/MIGR-61604.html
here is the sound driver you need...but remember that the problem might be from another point..anyway the silly stuff with sp3 and sp2 doesnt matter ...cause the sound driver its the same for all XP operating system ...sometimes its the same for vista too ...only in special cases need another ..
so ..download ...and after you remove from the system all the other drivers...( look into add remove programs from control panel ) I mean all other tries and any unfit drivers that ya might tried..restart ..run this one ...and it willwork ...
Oct 01, 2009 | IBM ThinkPad R40 2681
I got problem with installation IBM R40
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :- http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download You can download the various drivers and then you click on and run the variour drivers, they will then unzip and expand into a folder on C:\drivers Then install the various drivers from this folder.
Jun 16, 2009 | IBM ThinkPad R40 2722 Notebook
Think pad r40/2681(driver prob.i.e. usb/wireless/sound etc.)
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
You need to use a computer that has Internet access to download and transfer the files to your computer.
Mar 01, 2009 | IBM ThinkPad R40 2681
I fromat IBM R40 nOTE BOOK NO "ETHERNET CONTROLLER"
You need to download the driver to another computer then transfer it to your ibm by cd or usb drive or even floppy.
After you have the eternet installed then I would visit the Windows Update site and run a custom update so that it will detect missing drivers and install them. It might not detect everything but that's a good place to start.
Let me know if you have any other questions or problems.
Best of luck!
Feb 25, 2009 | IBM ThinkPad R40 2722 Notebook
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Thinkpad r40 - wireless disappeared
No Sound On My IBM R40
What I ask myself is, If sound and wireless are not working - what else might not be ok until you find out later, when you have documents and applications installed?
I would reset the R40 to factory settings right away. Hopefully that person hasn't removed the hidden partition...
You can check that by going into your Device Manager (Right-click "My Computer->Manage->Disk Management) and see if you see a Fat32 partition usually called "ServiceV001".
Restart your notebook and hit the blue button at the ThinkPad splash screen. A wizzard will lead you through the process.
Rescue and recovery will restore your laptop to factory state. It has an image of their default installation with all the software, settings, and drivers.
After you're done, you have to update the drivers to the newest versions. Look in you start menu and you will see an entry called either "IBM" or "ThinkPad" with a sub-menu that contains the software to update your computer.
If you want to manually update your drivers, go here, fill out the form and follow the prompts. (You will find the necessary information on the sticker on the bottom of your laptop).
It will get you to the right page.
If you have any questions, come back here and leave a comment. I am happy to help!
Dec 13, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 Notebook Logo
689 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
