Question about Cyber Acoustics AC-634 Consumer Headset
I have a head set, cyber acoustics AC-634. The microphone part is working but no sound is coming up
  • birdlady23 May 22, 2009
    no sound through the ear pieces. Mic. is working fine, though.
  • wutommy21 May 11, 2010
    How'd you get the microphone to work?
  • 25 Answers
Hi don, try looking at the ear pieces and see if there is not some plastic film covering the ear holes . ran into that on 2 of my motorlas. good luck
Posted on Jan 25, 2009
My problem is that i get great sound on the headphones but my pc isn't picking up the mic
The webcam itself usually has a built-in microphone.
Most likely you will need to go into the configuration setting of your webcam (probably available in Control Panel if you're using Windows) and deselect the microphone that is built-in to the webcam and select the mic input on your sound card instead.
I've seen this happen many many times.
Feb 04, 2011 | Cyber Acoustics AC-201 Consumer Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
Microphone isnt working
u have to set it up from the computer....go to control panel and audio configure and itll show the rest that would be easy for u to follow....
Oct 06, 2009 | Cyber Acoustics AC-634 Consumer Headset
Cyber acoustics ac-201 and it doesn't work!!
Hi itsonlyerin,
This has to be rather general as it's a bit hard to give you specific advise without knowing a bit more about your operating system and sound card.
Try checking the following:
(1) Headphone problem
First, I would try to determine if there is a problem with the microphone itself. Do you have another pair or a different model that you could try? If yes, then give them a go and see if the other ones work. If they do then take your ac201's back to the store and get a replacement. If you haven't got another pair then try them in another computer and see if you get a different result. If they work in a different computer then the phones are OK and we need to look into the computer hardware and software.
(2) Software Setup problem.
Have you made sure that on the recording controls that the microphone volume is turned up?
(3) Sound Card setup problem.
Some sound cards have multipurpose jack that for example can be switched between line input and microphone. Check with the card's documentation and especially check that the jack you are using is set to microphone and that you are plugged into the right one.
(4) Software problem - do you have the right drivers for your sound card loaded?
(5) Faulty Sound Card - try a different one.
Good Luck
Jul 06, 2009 | Cyber Acoustics AC-201 Consumer Headset
My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Cyber acoustic headsets
make sure that your mic is ot muted cause thats what happened to me also check it when ur done in your audio manager
May 26, 2008 | Cyber Acoustics AC-201 Consumer Headset
AC-740 : No Manual
does it have 2 plugs one for mic and headset or sterio plug for mono head set mono mic u would need input on phone that can accept that kinda sterio input ok for both
Jan 28, 2008 | Cyber Acoustics AC-740 Headset
Cyber Acoustics AC-840 USB Headset
heyo...for you online meetings...I am assuming you are using Skype. Check the volume settings in the TOOLS and OPTIONS, audio settings, audio in&out, using the drop down menu for microphone and speakers. Save.
If that isn't a problem, it could be a setting in Windows (also assuming you are using XP). Go into your Control Panel, SOUNDS&AUDIO, Audio tab, check your volume there.
Wayne
Dec 06, 2007 | Cyber Acoustics AC-840 Headset
Cyber Acoustics PC Microphone Not Working Anymore
Well to find out if your computer even recognizes it, you need to right click the white speaker on the bottom right of your computer. Select audio devices. More than likely it will tell you it isn't connected.
I uninstalled the sound completely from my computer. Then i restarted the computer. This will reinstall the drivers for your sound and the one you need for your mic. I have vista but this should still work for XP.
-right click on computer (should be on ur desktop or under start menu)
-select manage
-device manager
-click on the plus next to sound, video and game controllers
-right click on the audio (high definition audio device)
-select uninstall
- restart your computer.
This will do the trick.
your computer should recognize the mic.
Oct 27, 2007 | Cyber Acoustics CV-1064 Microphone
Cyber Acoustics AC-634 Consumer Headset Logo
247 people viewed this question
Top Cyber Acoustics Radio Communications Experts
Josh Whitehead
Josh Whitehead
Clementina Emerson
Clementina Emerson
Level 1 Expert
Tom Chichester
Are you a Cyber Acoustics Radio Communication Expert? Answer questions, earn points and help others
