Question about JVC RX-6010V Receiver
My jvc rx-6010v is OVERLOADING?
For the longest time i could play my music as loud as i wanted on surround sound then one day i am listing and it cuts out i look at the reciever and it says overload so i turn it off and turn it on and it starts playing again but not at the volume i had it at when i try and turn it up it says overload again and cuts out turn it off then on again and each time its lower and lower so i turned of surround sound and was listening via left and right speakers and it was fine could play loud again but then again that day came where even with surround sound off i get the overload how do i kill the overload?
    Habit-Forming:
    New Friend:
  • 18 Answers
Disconnect your less dominant speaker or switch from DVD to CD etc. Just had this problem and it fixed it
Posted on Nov 01, 2016
    Genius:
  • 1,175 Answers
HI...
You've overdriven the amp too many times and most likely blew an output amp or two.
It will need service or replacement
Posted on Apr 11, 2009
  • 20 Answers
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
SOURCE:
I have this JVC RX-6010V Receiver, how can I connect my microphone to the unit?
Get a microphone (with a) preamp and follow ITS instructions. It only accepts RCA Line Level analog signals.
Jul 05, 2011 | JVC RX-6010V Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
My JVC receiver won't play my left front speaker. The right one seems to work fine but when I plug in the left it is virtually silent. i too have had a few "overload" incidents and am running two JBL 8...
swap the wires around to see if the right speaker will give sound on the left channel. If it does, the it's a blown left speaker. If you don't get sound out the right one either, then the left channel ouput has a bad capacitor somewhere in it.
Jul 06, 2009 | JVC RX-6010V Receiver
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
SOUND CUTS OUT WHEN VOLUME IS PAST 15
thats to stop you blowing your speakers. you can make your volume louder via the equaliser/surround settings, but you will still not be aloud past the number 15 without it cutting out.
its an EU setting thats on most mp3 players too, so that people wont listen to music too loud, "nanny state".
hope this helps
kev
Oct 02, 2008 | JVC Audio Players & Recorders
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
JVC RX-6010V Receiver Logo
1,286 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
