Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
Until 3 months ago, the system was working fine.
About 3 months ago, the remote would work, but only when the light on the garage opener motor was off (after opening or closing the door there was a ~5 minute period where the remote could not open or close the door).
Recently, while resetting the garage door opener and remote via the button on the motor, it has ended up making the remote completely ineffective.
The motor unit is receiving the signal as the LED next to the reset button is flashing, but the motor is not responding.
The button on the wall works just fine still and opens / closes the door without any problems as always.
The same remote (alternate button) still works on the 2nd garage door opener.
The problem seems to lie in the wiring / relays in the motor unit, but I don't know where to look.
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Posted on Jan 27, 2009
2 Suggested Answers
  • 59 Answers
SOURCE: My lift master no longer operates the garage door
To remove the keypad, open the batter cover, remove the battery, now you will see the mounting screw, remove the mounting screw. Teknuw
Posted on Dec 27, 2010
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage master 1/3 HP Security Plus. Will go with remote, but remote is pushed to close, light flashes. How to reprogram???
You don't need to reprogram. You need to make sure your door sensors haven't been bumped and misaligned. Each of them has a small light that will be lit when they are properly aligned. Tweak them a bit. If the light doesn't come on you probably have a sensor that has quit working.
Sep 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close
It sounds like the door sensors have been bumped or somehow gotten misaligned. Tweak them until the light on each one is lit and not blinking. They must be pointed at one another.
May 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Remote opener
Have you tried to re-learn the remote? The instructions should be inside the opener cover.
Nov 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
451 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
