Question about Hotpoint Dryers
Need to change the belt on Hotpoint dryer 9325p and all point sseem to be spot welded
  • 8 Answers
SOURCE: change belt on hotpoint dryer
Try www.applianceaid.com/ge-dryers.html
Posted on Mar 27, 2008
  • 1314 Answers
SOURCE: changing a dryer belt
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .and put yours on
Posted on May 22, 2008
dragonsthatk
  • 547 Answers
SOURCE: how to remove top on hotpoint 473e dryer
top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
Posted on Feb 20, 2009
barkencoa
  • 3463 Answers
SOURCE: How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Posted on Mar 23, 2010
  • 8 Answers
SOURCE: i have a hotpoint ctdoop
i have worked on the hotpoint ctdoop and the vtdoop in every aspect of repair. I can replace the belt on these machines within about 15 minutes or so but it takes a long time to get the hang of it. For the basic diy person, changing the belt is very very difficult to do. The only way to do this with out breaking your heart and the wife and kids running out the front door from all the cursing and swearing, is to strip the machine down to the base and replace the belt. As i said, once you can manage this, its only a fifteen minute job once you know what you are doing, but i would suggest you call out an engineer to do the job for you.
Posted on Jan 31, 2011
How do i replce belt on hot point tvm572
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 27, 2013 | Dryers
Mar 23, 2010 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
I have a Hotpoint Dryer and the belt snapped, we purchased a replacement belt but are having a hard time figuring out how to install the new belt. The instructions call this belt a drive shaft. Please...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 15, 2009 | Hotpoint Dryers
How do i change the belt on my hotpoint tumble dryer
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Good luck,
I hope this helps
Nov 12, 2009 | Hotpoint Dryers
Drum not spinning
sound like the rear bearing is stuck and the noise is the belt slipping on the idler pully and rear bearing needs replaced
Sep 15, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
20 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
